Replacing Turbo on '97 850 GLT Wagon
Old Feb 24, 2006 | 05:06 PM
ProMischiefMaker's Avatar
Default Replacing Turbo on '97 850 GLT Wagon
The turbo in my '97 850 GLT wagon is shot. I was just wondering if anybody knew how hard it would be to replace it on my own. I do the vast majority of car repairs myself. But I've never replaced a turbo and I was just curious if it would be worth it to just give it to a shop to do. Thanks.
Old Feb 24, 2006 | 05:08 PM
Default RE: Replacing Turbo on '97 850 GLT Wagon
oh and also I was wondering if it would be possible to use the T5 turbo, or even the R turbo. I've heard that the ECU regulates the boost pressure, so I wasn't quite sure if I used the T5 or the R turbo if my ECU would screw up my fuel mapping or if it would work fine. Thanks again.
Old Feb 24, 2006 | 08:40 PM
Most people that I have heard that done it had the ECM upgrade.
Im not sure if it would mess it up or not.
Old Feb 25, 2006 | 02:14 AM
ok, thanks a bunch man, I'm waking up bright and early to hit the junkyard to see if they have any 850 GLT's because I kinda need to get this fixed as soon as possible.
Old Feb 25, 2006 | 12:39 PM
sp5368's Avatar
It is not to bad to replace the turbo, just need to drain oil and water lines from the turbo.I just used my oil changing pan and let the fluids drop in it .I think that car has a SAS valve if you take yor heat shield off you should see it.The boost on that car is only 6psi because of the turbo if you are not going to remap the ecu I would leave the 13g on the car.
Old Feb 25, 2006 | 05:27 PM
ok thanks a lot. I couldn't find any similar turbos at the junkyard and I finally got mine out today. It took me a while, but eventually it came out. I think I'm just gonna get this one rebuilt or see if I can find an already rebuilt one. Thanks for the quick responses.
Old Feb 25, 2006 | 05:47 PM
sp5368's Avatar
look on line good deal on those turbo very inexpensive, don't forget to get the copper seals and gasket for the return lines
Old Feb 26, 2006 | 04:46 PM
Yeah I'm about to start looking online for it. Do you guys have any idea what the turbo model designation numbers are. It just occurred to me that I'm not sure what they are. Oh and thanks for the tip about the copper rings. One of my friends used his old copper rings and his turbo dumped coolant and oil everywhere.
Old Feb 26, 2006 | 07:05 PM
robert213's Avatar
Have your current turbo rebuilt professionally. It shouldn't cost much more than $300. Remember to use a new turbo oil feed line. Shop and Compare, starting with Forced Performance...
And one other thing... For the price of a rebuilt, your existing turbo housing can be over-bored for a larger compressor wheel, such as -15G, -16G, -16T, or -17C.
Volvo owners have been recommending...
http://www.dallasturbo.com/
Majestic Turbochargers of Dallas
1000 S. Wildwood
Suite 10
Irving, TX, 75060
http://www.hirschinds.com/
HIRSCH FOREIGN
P.O. BOX 18063
PHOENIX, AZ 85009
Mitsubishi owners use...
http://www.turbochargers.com
Turbochargers.com
5410 Burr Oak Drive
Houston, Texas 77092
Tech Line: (713) 681-1111
Order Line Toll Free: (800) 749-7111
Fax: (713) 939-1111
Email - Turbo@turbochargers.com
http://www.forcedperformance.net/
Forced Performance
671 New Hope Road West
McKinney, TX 75071
Phone: (972) 984-1800
Fax: (972) 984-1802
Sales@forcedperformance.net
Rebuild@forcedperformance.net
VolvoBB
Jul 28, 2013 11:59 AM
gentlejax2
Apr 15, 2011 10:21 AM
tmixdorf
Apr 11, 2010 11:49 AM
eddiecortes112683
Feb 22, 2009 08:37 AM
