engine swap
Old Dec 2, 2011 | 11:33 AM
I am Phil's Avatar
Default engine swap
Looking at getting a 95 non turbo 5spd 850. It runs but nocks when revved.....I have 2 850 motors ones got a turbo one does not. Both have auto trannies. I plan to use the non turbo one. I dont know the year of the motor that i have does that matter?? And is there a difference auto vs stick engines?? He wants 400 bucks and i have a motor Should i go for it?? btw anyone want turbo 850 motor and trans ?? Thanks ZR
Old Dec 2, 2011 | 11:37 AM
Should be no problem with the motors, the trannies are different but you are hooking it up to a manual so I think you'll be fine.
Old Dec 3, 2011 | 02:11 AM
I am Phil's Avatar
Called a junk yard near here that deals in imports. And they made it sound like a big deal..as they wanted the vin and what not. Called a big parts yard and nothin said bout vins just year ect ect. Stranberg parts tryin to sell me on something or what?? Lol If i were to care how would i find out what year engine i got??? i assume its got numbers on the block some place or maybe the trans?? Thanks for the feed back Zech
Old Dec 3, 2011 | 09:17 AM
Well, I'm far from an expert on swapping motors. I do know that SN's on the front of the t-blet cover has the motor specs but some do have different things like EGR, PCV changes, and stuff like that. You may want to wait for a pro or ask guys on MATT's site. There is a guy here trying to get one started that he swapped a '99 motor into a '95. He's stuck.
Old Dec 3, 2011 | 09:39 AM
remark90's Avatar
That guy would be me . I do know that you will need the 5th & 6th of your vin, as well as weather you have an air pump or not. My biggest obstacle installing the engine was the 99 front mount is a little different and I had to buy one for a 99, than it fell right into place.
I might be a little naive here but I truly feel that my issue is not with the replacement engine, but with the car. The reason I feel that way is I have no spark from the coil. When it warms up a little here I have replacement cam & crank sensor I’m going to try, Kent.
Old Dec 3, 2011 | 11:23 AM
Hey Kent: You know I wasn't trying to knock you just trying to make sure I didn't misslead Phil into thinking it was a piece of cake and I knew it all. Hope that cam sensor works out for you. It got my daughters S70 running real quick.
Old Dec 3, 2011 | 12:06 PM
remark90's Avatar
rspi, not to worry man didnt think you or anyone was, only offering what I have learned when I started shopping for my replacment engine.
Old Dec 3, 2011 | 12:08 PM
remark90's Avatar
BTW, cam & crank sensors did nothing for me! Grrrr
Old Dec 3, 2011 | 12:50 PM
The motor is turning over, right?
Old Dec 3, 2011 | 01:00 PM
remark90's Avatar
Oh ya, I also have fuel, just no spark from the coil. Is there fuseable links on these cars?
JDvolvo33
May 16, 2012 09:53 PM
McQuattro
Jun 19, 2009 07:29 AM
bsamole
Apr 26, 2009 06:27 AM
Superfly
Sep 22, 2005 09:37 PM
s60r
Aug 13, 2004 03:39 PM
