is this even possible
Old Feb 1, 2008 | 08:38 AM
new850driver's Avatar
Default is this even possible
pulled codes today and got (pull up a chair)
A1
[ol][*]124[*]114[*]134[/ol]A2
[ol][*]111[/ol]A3
[ol][*]444[*]211[*]212[/ol]A6
[ol][*]214[/ol]A7
[ol][*]122[*]132[/ol]Please help or should i park on the next train track i see
Old Feb 1, 2008 | 09:30 AM
JPN's Avatar
JPN
Default RE: is this even possible
So I did.
A1:Transmission Control Module
114 = Mode selector switch circuit malfunction.
124 = Short to ground in mode selector switch circuit.
134 = Incorrect load signal.
*Most likely your PNP or the micro switch has gone south. A DIY fix.
http://www.fcpgroton.com/volvo850tranny.htm
A2: Fuel System Control
1-1-1 = system normal.
A3: ABS
211 = Left front wheel sensor signal absent when moving off.
212 = Right front wheel sensor signal absent when moving off.
444= No supply to hydraulic unit valves.
*Most likely your ABS module is shot.
For '96-'97: http://home.earthlink.net/~vicrocha/
A6: Ignition
214 = RPM signal reversed or faulty (?). This may not be the correct description, as it was taken from the fuel control testing.
*Reset the code and see if it returns.
A7: Instrument
122 = Temperature sensor/interval too short.
132 = Engine speed sensor signal incorrect.
*Is your outside air temp gauge working? And does the coolant temp indicates at about 3 O'clock position? Reset the system and see if the same codes return.
They don't sound too bad, as long as the car is running fine.
Specify your model year. If '93-'95, we can help you reset the ECUs. If '96-'97, you would have to visit a local auto parts shop such as AutoZone, have them hook up an OBD-II scanner and retrieve codes & reset them. They officially cannot reset emissions-related codes but they can "fat-finger" if they are decent & helpful.
Wait to for other members to help you with the ignition system code.
JPN
Old Feb 1, 2008 | 09:38 AM
wow fast reply. sorry i always forget to mention it's a 1994 non turbo 850 wagon..,
Old Feb 1, 2008 | 09:54 AM
JPN's Avatar
JPN
Just found the code for the ignition:
214 = VSS (Vehicle Speed Signal?) intermittent.
FYR:
http://volvospeed.com/Repair/a1.html
http://volvospeed.com/Repair/a2.html
http://volvospeed.com/Repair/a3.html
And see attached. Other members would be coming in soon.
Good luck,
JPN
[IMG]local://upfiles/6892/8459F6308F7F4D95B7627EE04D408D29.jpg[/IMG]
[IMG]local://upfiles/6892/806A4B5AA0E449A698E54DF47F124EEF.jpg[/IMG]
[IMG]local://upfiles/6892/132C1194D6FB45349528D4ECE32D6DED.jpg[/IMG]
[IMG]local://upfiles/6892/AE3CB1B77522480FB3ED79EA4CEA3247.jpg[/IMG]
Old Feb 1, 2008 | 09:55 AM
JPN's Avatar
JPN
2nd half.
JPN
[IMG]local://upfiles/6892/1F735756294648D8ADDBDEF9DF2DC6F1.jpg[/IMG]
[IMG]local://upfiles/6892/43AA4415F695495BBA382B7D2208063C.jpg[/IMG]
Old Feb 1, 2008 | 01:48 PM
thanks again jpn...still haven't had any sputtering prolems since i tied back that wire stalled out twice today notsure if it's related to all the codes above or that wire again. i might need to redo the wiring on this car or something
Old Feb 1, 2008 | 02:53 PM
info2x's Avatar
Clear the codes per JPN's instructions and see what's coming back.
[align=left] [/align]
gingersnap
Jan 10, 2012 11:33 AM
hkburke
Jan 18, 2008 05:03 PM
repeatclicks
Aug 31, 2007 04:37 PM
ludeless
Jul 14, 2007 09:34 AM
arb173
Jan 31, 2006 10:04 PM
