exhaust issue, blue smoke?, burning oil?
Old Mar 24, 2008 | 11:26 PM
blue_boi23's Avatar
Default exhaust issue, blue smoke?, burning oil?
So this may be a lengthy one, but for years my 850 turbo has been burning oil and pouring blue smoke out the exhaust, especially at stops. It used to be a rare occurence and small amount, but lately its been POURING out at stops surrounding the entire car and dumping out while driving. A trip to the dealership later and we got about 7ish oil leaks fixed and it temporarily stopped. An oil change did little as well. Any advice?
Old Mar 25, 2008 | 08:41 AM
Psaboic's Avatar
Default RE: exhaust issue, blue smoke?, burning oil?
I would find out what oil leaks the dealership found, and start fixing those permanently. IF it still does it after fixing leaks, then you most likely have internal engine damage/wear such as bad valve guides/worn piuston rings.
Good luck
Old Mar 25, 2008 | 11:02 AM
JPN's Avatar
JPN
I would replace the PCV components as a kit. Techsuggested that sometimes clogged PCV can force oil to burn.
JPN
Old Mar 25, 2008 | 09:41 PM
blue_boi23's Avatar
we already did the maintanence on the pcv sys. If it is the piston rings or valve guides, whats the story on the repair? Major? Expensive? Best left with professionals?
cvearer
Sep 4, 2014 10:26 AM
Blue91SL
Aug 15, 2014 08:34 PM
BigBear854R
Nov 27, 2011 06:26 PM
vwvolvo04
Jul 12, 2010 02:11 PM
zbrink
Apr 3, 2009 10:33 AM
