EXPANSION TANK OVER FLOWING
Old Nov 14, 2007 | 07:19 AM
  #41
AlX's Avatar
AlX
Default RE: EXPANSION TANK OVER FLOWING
BTW... on the expansion tank it reads " use VOLVO coolant only " !
what sort of coolant shall i top up with to match the volvo requirements?[sm=WTFsgign.gif]
Old Nov 14, 2007 | 08:16 AM
  #42
axelm's Avatar
Standard coolant is ok. Told ya it was the expansion tank or the cap
Man, you were lucky. You could have fried the engine by driving with very low coolant level.
Old Nov 15, 2007 | 05:38 AM
  #43
AlX's Avatar
AlX
umm, today i lost a bit of coolant, there is sum sort of leak or somthing it was way off the radiator tank, so i knew its either from the hoses or somthing...
i just tightened the screws ill see how it'll go.
i might have to change the hoses too.
BTW... i took picture of the old and new expansion tank. ill post em soon. You;ll see the diffrence [8D]
Old Nov 15, 2007 | 05:41 AM
  #44
AlX's Avatar
AlX
ORIGINAL: axelm
yes, l just had a gut instinct to pull over and turn off the engine, although the engine was so HUT!!
car runs so smooth now and my fuel consumption is down as well. and car accellerates pretty excellent.
ill have to keep my eyes on that leak of coolant from sumwhere it happens when the car gets warm, when the engine is cool it doent leak, so iam gussing its one of the hoses.
they are really old.
Old Nov 15, 2007 | 08:00 PM
  #45
axelm's Avatar
Did you change the thermostat too?
It's not a smart move to keep old coolant hoses.
Old Nov 16, 2007 | 05:40 PM
  #46
AlX's Avatar
AlX
ORIGINAL: axelm
i took the car to 2 mechanics yesterday, i found out that it was a damaged water pump, so he's gonna change the pump.
hopefully thatll be the end of it.
The problem occured due to the fact the new expansion tank put pressure on the old pump, that causes it sum-how to blow the gasket or somthing.
- from my understanding this car hasnt been serviced for ages, hince the problems...
- i am going to lodge a complant to FAIR TRADING australia and i might get my money re imburst from the dealer
Old Nov 16, 2007 | 07:19 PM
  #47
axelm's Avatar
Have the mechanic change the timing belt and tensioner when he changes the water pump. He should not charge you more than an extra hour of labour, and the parts are not expensive.
Old Nov 17, 2007 | 12:51 PM
  #48
Systek's Avatar
ORIGINAL: axelm
x~
If he is going to change the pump and you know it hasnt been serviced in ages, then go ahead and get the timing belt and tensioner replaced as well...
Old Nov 19, 2007 | 03:23 AM
  #49
AlX's Avatar
AlX
ORIGINAL: Systek
ORIGINAL: axelm
x~
i went down to another mechanic he was asking for $500 to $600 Australian i gave him the finger [&:] I sort of know the other mechanic he is a very reputable european cars mechanic, hopefully hes be cheaper - ill let you know how it all goes...
curtisckey
Sep 22, 2019 12:26 AM
jonqu
Aug 11, 2013 11:36 AM
jlhoward06
Feb 5, 2008 11:17 PM
nebsch
Oct 9, 2007 09:03 PM
snulma1
Dec 28, 2006 11:19 AM
