First post and first Volvo.
#41
I use to do all my stuff at home. Recently I moved into an apartment and now do all my work there. I was a little afraid at first. Then I seen some guy on the side of the office building with his rear end and tranny on the ground. I was like WHATTTT!!! It's on now. I did a head on our S70 last month. Some don't want you changing your battery, others don't care.
#42
#43
does it tell you when a tune up was done?at 30k l would be looking at spark plugs. if the plug wires,distributor cap and rotor have never been changed you might as well just change it for better performance.if the timing belt has 30k on it, you probably have like 40 to 50k to go.
#44
Okay cool. The little stuff is important. I would like to get it dialed in.. what about the pcv system? I didnt see anything in the records for that..
These people took this car to the dealer if they ran over a pebble.. I mean I have 90+ receipts and records galore even the original window sticker..
Bought in Lexington, Kentucky for $35k back in 1996 haha
#45
#46
Nov 25, 2011 they had the spark plugs, ign wire, fuel filter, plate cleaner, and fuel injectors done at 125k miles
May 19, 2011 They replaced spark plugs, new radiator put in with new radiator hoses at 121k miles
March 23, 2011 They replaced the fuel pump and the relay at 120k miles
October 7, 2005 Starter and starter motor replaced at 91k miles
HAHA. This is great.. now I am just stuck in what to do.. I will check the pcv system today. Distributor cap and rotor? Intake? Turbo hoses?
#48
I would use the records at the guide. I would not do the timing belt until it's due. If the wires were replaced within the last year, I wouldn't touch them for 100k or if they need it, like it runs rough. Do things that you haven't seen receipts for, like change brake fluid and coolant, etc.
#49
When I got my wagon, the tb sticker said 106,000 in 6/2006 so I didn't replace it until 205,000 3/12. My wires were dated 36/10 so I know it had a tune up after Aug 2010 so I'm not doing one until 220,000, plugs only.
If you have service records, focus on the stuff that they did not do and do the other stuff when it's due or you have a problem with it.
#50
Thats it! I am just gonna order the distributor cap and rotor and the Snabb intake!
I finally got the time to joyride in it this afternoon and stock this thing is damn quick. Threw it in sport mode and got up to 100 before I knew it. Now time to open those pipes a little more.
Anyone have any mpg tips? Other than intake and filter..
#51
There is an ENTIRE THREAD stuck on MPG in the 850 section. Read through it. Most get 19/27 but you can do a little better. My personal best was 25/29.
Definately check/do the PCV system. You do NOT want to blow any seals in that thing. May want to do a tranny fluid change as well.
#52
#55
I dont trust those. They are usually always over clocked by the manufacture. I sold cars for Honda and got to know that all the service guys say dont trust them..
My 2012 Civic sometimes says that I get 50 mpg on the freeway.. yet I can only go 410 miles on the tank.. haha
#57
