flywheel question...
Old Oct 15, 2009 | 07:42 AM
anton850t's Avatar
Default flywheel question...
I just had a new starter put in my 850 Turbo, when I went to pick the car up my mechanic told me that I had a "small amount of gear damage on the flywheel". Could someone tell me what that means, and if I need to worry about it. Thanks for any help.
Old Oct 15, 2009 | 09:03 AM
fcpgroton's Avatar
Former Sponsor
More then likely, the old starter wore down the teeth on the outside of the fly wheel. As long as it is not really bad, it should be fine. If it is bad, you will have a hard time starting the car.
Old Oct 15, 2009 | 09:35 AM
anton850t's Avatar
Default flywheel...
Thanks, I guess I'll just have to keep my fingers crossed.
Old Oct 15, 2009 | 03:02 PM
boxpin's Avatar
When you start the car do you ever hear a grinding noise and the motor does not turn over? If so, thats what he is talking about. When it gets bad the starte will not engage the teeth on the flywheel. It is common to have some wear there. He was either trying to make a buck or being a over protective, cover your butt mechanic.
Rambler875
Aug 1, 2013 11:27 AM
stirtog
Dec 2, 2011 03:22 AM
jmarble
Jun 27, 2010 12:33 PM
brownnb
Jun 11, 2007 05:09 AM
ProMischiefMaker
Sep 29, 2006 09:16 PM
