Fog Light Installation
Old Dec 12, 2007 | 03:29 PM
Blozend's Avatar
Default Fog Light Installation
Hey, I was wondering if anyone could help me out. I can't seem to figure what's up.
I have a 96 850 base. I wanted to wire some fog lights. My car is prewired so it made things a lot easier. I've found the dummy plugs under the bumper and wired them. I've installed an OEM switch into the dash with the prewired harness. I've checked the fuse, and it's still intact 15A.
I don't get what step I'm missing. The Fog lights just aren't working for me. I'm starting to wonder if the foglight switch i have, simply doesn't work.
Any input is appreciated. I'm definitely not a born mechanic! Thanks
Old Dec 12, 2007 | 04:35 PM
RedTurbo850's Avatar
Default RE: Fog Light Installation
Perhaps try reversing the polarity...
It worked for my hids.....
Old Dec 12, 2007 | 05:12 PM
Blozend's Avatar
Do you mean simply changing the postive and negative flow into the foglights? I tried that. Still no change.
When the dashboard lights come on, is the fog light switch supposed to glow at all? It's not glowing.
Old Dec 12, 2007 | 05:21 PM
92Typhoon's Avatar
ORIGINAL: Blozend
I think that depends on the type of switch. On some cars, the switch only glows when in the "on position," while in other cars, it glows all of the time so you can find it in the dark.
You said your car was pre-wired, did you have to splice wires together, or where there plugs? You may have a bad ground somewhere in the circuit, or possibly a bad/disconnected power wire, and as you said, you may have a bad switch. They have been known to go bad. Doyou have a test light? You could always turn the switch on, and test the power wire to the fogs and see if power is making it to the lights or getting interrupted somewhere inbetween.
That makes me want to check our Volvo. I'd love to put some fogs on it.
Do you have pics of your setup?
Old Dec 12, 2007 | 06:05 PM
You need to install 2 relays for the lights to work if the car didn't come with them.
I am fighting the same thing now.
Old Dec 12, 2007 | 06:22 PM
Blozend's Avatar
A Test Light? That's a brilliant idea! I'll defintiely have to checked that out. I actually don't have any pictures at the moment, but i can get some when the sun comes back. They're mounted using a couple of screws to mount the bumper. It's not exactly the sleekest of things, but it's not too shabby.
I haven't spliced any wires. I simply used the ones provided. The fog lights had dummy plugs, and the dashboard switch already had a harness. Its very possible that the actual switch is broken.
2 relays? Well darn. Where do I have to wire?
Old Dec 12, 2007 | 06:44 PM
The relays go under the dash.
Also sorry it is 3 realays total.
2 under the dash and the 3rd one is the headlight relay for a car with foglights.
Thats what I need is the headlight relay with foglights.
Old Dec 12, 2007 | 07:25 PM
Blozend's Avatar
Ok, I'm just making sure i know exactly what you're talking about because i have trouble keeping up.
I have been getting better aquainted with under the dashboard area. I do believe i've seen a couple of places for relays to be put in. I want to say one is lime green and the other is yellow. Those would be where i simply buy a generic bosch relay and install?
Now this 3rd one. Do i need to get that relay and replace the one that i have?
Old Dec 12, 2007 | 08:13 PM
Yes you will need to swap your headlight relay and install the other 2.
One is actually a bridge.
Attached is a few pics first is the parts break down.
Second 2 is the relay locations and what they are for.
Hope this helps.
Old Dec 13, 2007 | 10:18 AM
92Typhoon's Avatar
Wow! good info Tech!
That's on my list of things the Volvo needs next year... *right click, save as*
Old Dec 13, 2007 | 05:02 PM
Blozend's Avatar
This is my attempts to mount foglights without having holes in the bumper for the correct position. I figure at night it will still look pretty smooth.
Thanks Tech! I'm glad you could clear that up for me. I was having a bit of trouble finding exactly what i needed to know!
[IMG]local://upfiles/4655/DC557D9B862243A8B7C028A501BABB96.jpg[/IMG]
[IMG]local://upfiles/4655/D0E57127D8534DA08CA62D83B735DD70.jpg[/IMG]
Old Dec 13, 2007 | 06:56 PM
That should look good.
FYI if you look really close where they are supposed to be there is an outline you could cut out if you are installing factory lights.
But you would also need the little rubber o-ring to go in the hole.
Old Dec 13, 2007 | 09:34 PM
KnoxVolvo's Avatar
I noticed that my fog lights on mine aren't working and was thinking about replacing. I don't know if they are factory or not, but I do have all hardware in the interior. Mine are the square lights. Which ones were the factory model-round or square?
Old Dec 14, 2007 | 05:50 PM
Round on the 850 Unless it is a 1993.
Old Dec 14, 2007 | 10:45 PM
KnoxVolvo's Avatar
It is a 1993, so I assume they are square? Thanks
Old Dec 15, 2007 | 05:57 AM
Yes the 1993's were square.
piv15
Oct 14, 2012 10:40 PM
mrdabbas
Sep 6, 2012 01:59 PM
BRATHAMAN
May 10, 2009 10:17 PM
junkprospector
Apr 7, 2008 04:38 PM
RedBrick
Feb 16, 2006 11:36 PM
