Found what may be my problem
Old Jul 4, 2010 | 03:16 AM
ibified's Avatar
Default Found what may be my problem
So I had my idle air control valve off to check to see if it was clean, because i've been experiencing a bit of a rough idle lately. I noticed that the hose that goes between the idle air control valve and the vacuum tube has an inch long split in it.
I'm assuming that boost would easily blow out of this line, but what else could this cause? Would it make the car run rich as well?
Old Jul 4, 2010 | 08:27 AM
Yes it will make the car run rich. It is unmetered air.
LC Garage
Aug 24, 2011 01:48 PM
gilber33
May 15, 2011 08:23 AM
Bender
Sep 14, 2006 12:25 AM
tech
Oct 23, 2005 03:47 PM
Geetarslim
Mar 12, 2005 12:30 PM
