Front Cigarette Lighter Power Plug won't work. Where is the fuse for it?
Old May 30, 2012 | 10:10 PM
1995Volvo850's Avatar
Question Front Cigarette Lighter Power Plug won't work. Where is the fuse for it?
Guys, that socket won't work. Where is the fuse I should replace?
Thanks in advance!
Old May 31, 2012 | 06:55 AM
94850Turbo's Avatar
under the hood on the driver side of the car.
Fuse 30 - 10 Amp
Cigarette Lighter
Old May 31, 2012 | 07:42 AM
boxpin's Avatar
Be sure to check the cig lighter with a test light not just plugging something in. The Pos contact in the bottom of the cig lighter can become corroded which causes everything you plug in to not make contact and appear to not work.
Old May 31, 2012 | 09:01 AM
snagbranch's Avatar
Yeah, check the fuse first, but the problem is likely down to to no contact in the cig lighter. I had to replace mine. The new part was not the right size but I was able use the components to make it work.
Old May 31, 2012 | 06:33 PM
Ok, I checked the fuse and it was fine, so I guess now I should test my socket.
Time to get the multimeter out!
Old May 31, 2012 | 10:44 PM
boxpin's Avatar
I had to put a dremel down in there to clean it up. Works great now.
Old May 31, 2012 | 11:22 PM
I'll try that if I find corrosion.
Old Jun 1, 2012 | 01:08 PM
I ended up replacing mine. I got one at Autozone for 9 bucks. It was part number 225051408 but I know it's carried at Oriellys too. This one dropped right in and has the lighted ring like the OEM one. I even changed out the amber ring the new one came with for the green one from the original that failed.
Attached Thumbnails Front Cigarette Lighter Power Plug won't work.  Where is the fuse for it?-cigarette-lighter.jpg
Old Jun 1, 2012 | 10:16 PM
Cool! That seems like the way to go.
xc90mom
Jun 13, 2012 07:47 PM
mark_disfree
Dec 19, 2008 01:10 AM
bwaarp
Dec 24, 2007 04:27 PM
newtome
Sep 25, 2007 07:47 PM
m_schiff83
Aug 10, 2007 05:06 PM
