fuel gauge needle is off
Old Jan 28, 2016 | 08:53 AM
Eden Ochoa's Avatar
Default fuel gauge needle is off
Have 1996 850 Turbo sedan. When tank is full the gas gauge needle will only go up 2/3 of the way, when nearing empty, needle is below red line. gas light does work. Can I just remove instrum. cluster and manually turn needle to top (after a fill up)? will that fix it? If not can I just replace the gauge/motor behind panel or do I have to replace instrument cluster? THANK YOU!
Old Jan 28, 2016 | 01:06 PM
sounds like the problem is in the sending unit or float not the dash cluster. Sure you can open up the cluster and pop off the needle (similar to the process for fixing the odometer gears) but that seems to fix the symptom not the cause. If you are interested, I have a spare instrument cluster (odometer doesn't work and the LED display may/may not work) from a 95 850 Turbo you can experiment with... (gas gauge works). Let me know if interested.
Old Jan 29, 2016 | 03:02 PM
boxpin's Avatar
Test the sensor range before you change anything.
The sensor range is from 7.5 Ohms to 327.5 Ohms
londiek
Jun 13, 2013 02:03 PM
Mr Sheen
May 12, 2008 08:14 AM
van850
Jun 21, 2006 03:24 AM
