fuel pressure regulator
Old Jul 13, 2009 | 12:57 AM
blackbrick's Avatar
Default fuel pressure regulator
Need to change FPR due to leaking fuel into vacuum tube.
What is right procedure to take fuel rail off? Do I need any new O rings or seals to put it back?
Old Jul 13, 2009 | 05:12 PM
Ozark Lee's Avatar
You should be able to just snap the aluminum cap off and replace it without removing the rail.
...Lee
Old Jul 13, 2009 | 06:05 PM
blackbrick's Avatar
Thanks Lee,
I tried that but couldn't reach to unscrew two screws that hold FPR on the rail. Is there some special way to do it?
Old Jul 13, 2009 | 06:20 PM
850tony's Avatar
there is three 10mm head bolts holding the rail onto the motor. take those out all the way and then wiggle the fuel rail off.
you *should* replace the injector orings, but its not *needed*.
Old Jul 13, 2009 | 06:31 PM
blackbrick's Avatar
How about relieving pressure and disconnecting fuel line?
Like Lee's idea better but don't know how to do it.
Old Jul 13, 2009 | 06:34 PM
850tony's Avatar
the fuel line doesnt need to come off, but it makes it easyer.
to take the pessure out use the valve on the end of the fuel rail
Old Jul 13, 2009 | 06:46 PM
blackbrick's Avatar
Thanks Tony
Old Jul 13, 2009 | 07:23 PM
850tony's Avatar
any time
Old Jul 14, 2009 | 04:13 PM
blackbrick's Avatar
Strange thing, just found out that my car has fuel pressure damper not fuel pressure regulator. What is deference beside price ( damper is half price $52)? There is little deference on pictures.
Attached Thumbnails fuel pressure regulator-damper.jpg   fuel pressure regulator-14251.jpg
Old Jul 14, 2009 | 04:44 PM
850tony's Avatar
both the same...
Old Jul 17, 2009 | 04:38 PM
blackbrick's Avatar
Update
Fuel pressure damper replaced. Really easy job. Much easier than I thought, 20 minutes top.
Most important this fixed long lasting problem of hard start when car is warm
Old Jul 17, 2009 | 07:59 PM
If you have the dampner on the rail then the regulator should be in the fuel line at the back of the motor by the body.
MntnDewMan
Apr 3, 2024 04:05 PM
slsnumber1
Mar 15, 2011 02:55 PM
Buck
Dec 28, 2005 01:28 AM
cdunning
Dec 28, 2005 01:27 AM
cdunning
Dec 27, 2005 02:58 AM
