Gas Mileage down
Old Aug 11, 2016 | 11:29 AM
shirley's Avatar
Default Gas Mileage down
Hello! My 1995 Volvo 850, 230,000 is starting to get about 5 miles per gallon less than it used to, 20 mpg instead 25 mpg before. I have noticed it is a little chuggy when I start moving and the rpm's seem higher too. Any suggestions are greatly appreciated.
Thanks!
Shirley
Old Aug 12, 2016 | 11:02 AM
Turbo or NA? Is there a check engine light on? any increased soot out of the tail light? How's the tune on the car - plugs/wires/rotor/cap? Its not uncommon for an oxygen sensor gone bad to drop mileage but that usually presents with a check engine light. Start by inspecting vacuum lines (including the tree under the throttle cable spool cover), plugs, wires, air filter etc. Then go into the diagnostic port and see if there are any stored codes. volvotips.com has a good write up on how. If its a turbo, inspect the air tubing from the turbo to the intercooler to the MAF. Finally, inspect the MAF, idle air valve and intake for any dirt, oil etc. Clean if need be with CRC MAF cleaner.
Old Aug 22, 2016 | 12:30 PM
shirley's Avatar
Thanks for your response. It is not a turbo. I am going to take it in for a tune up tomorrow. I will ask them to check all the things you mentioned.
jldriggers
Jan 27, 2012 10:55 PM
gr8gatzby
Aug 10, 2005 03:28 PM
JCVolvoS80
Jun 23, 2005 10:24 PM
Carbuff
May 9, 2005 07:04 PM
jedihookah
May 3, 2005 03:54 AM
