Gas smell, low milage.
Old Dec 7, 2009 | 06:38 PM
tobolate's Avatar
Default Gas smell, low milage.
I have a 1995 850 turbo sedan, every once and awhile when driving it within like 30 minutes of turning it on, it smells like gas, I figured maybe it was just needing to warm up so it was running rich. Then I noticed I'm getting 14 mpg, again, seemed low but I have a lead foot. I checked my fuel lines and they appeared "wet" however I wiped some of the wetness off with a paper towel and it was black, and did not smell like gas.
Basically what I'm asking is if you guys think my fuel lines are leaking because of the smell/low mpg, or if its normal. thanks.
Old Dec 11, 2009 | 08:36 PM
There could be a leak somewhere. Try checking the fuel pressure.
Old Dec 14, 2009 | 09:19 AM
fcpgroton's Avatar
Former Sponsor
Could be a leaking fuel line or even a bad injector seal that is leaking. I would check the fuel pressure and all the lines. When you check the fuel pressure, make sure that the pressure does not drop when the car is turned off.
dcjcdc
Sep 14, 2008 05:07 PM
2002XC70
Jul 30, 2008 07:24 PM
dman777
Jan 23, 2008 12:08 AM
iamnickcarter
Oct 31, 2007 02:45 PM
arejohn
Mar 29, 2007 01:53 PM
