gauges! About to add to my 850
Old Sep 1, 2013 | 02:11 AM
gdog's Avatar
Default gauges! About to add to my 850
I will be likely adding AFR and manifold pressure gauges to the 855T in near future.
Recommendations on gauge brands/sources and mounting locations please. Rather not put them on A pillar if I can avoid it; really want to keep stock look as much as possible.
Appreciate your input!
Old Sep 1, 2013 | 09:26 AM
97black850's Avatar
might be able to fit them in the vent
Old Sep 1, 2013 | 11:46 AM
VTBricked's Avatar
Replacing your double-decker head unit with a single height might give you enough room.
Old Sep 1, 2013 | 12:36 PM
gdog's Avatar
Yeah, actually thought about that, but still need rather small gauges to fit there.
Sorry 97black850, but i would still like to use my vents.
Might need to cut holes the dash possibly..
Gauge recommendations?
Old Sep 27, 2013 | 12:22 AM
gdog's Avatar
FYI: ending going w/VTBricked suggestion and think it turned out quite well. There is just enough room! Gauges are 2.063" diameter and 1 din height is about 2.400"; i.e. you have about an 1/8" to spare on top and bottom.
Went with AEM gauges. Will post pic soon.
Old Sep 27, 2013 | 08:23 PM
gdog's Avatar
Yeah it's not optimal for viewing so don't ck 'em while you're cutting thru traffic and if you need a 3rd gauge you'll need another option..
Old Sep 27, 2013 | 11:27 PM
Clean and professional, well done
Old Sep 29, 2013 | 04:57 AM
ibified's Avatar
I am running autometer ultralights in mine - love them. I have 3 on the A-pillar (wideband AFR, boost, and oil pressure) and 3 in the area above my (now single din) radio (egt, coolant temp, and fuel pressure).
Old Sep 29, 2013 | 08:51 AM
What is EGT?
I like the extra info but I do NOT like anything to look at that low. I actually ran off the road not long ago trying to adjust the AC in a Saturn that had the controls down in front of the shifter.
I have seen 3 gauges under or above a single DIN radio. The best place is in the pod or dash somehow. I had a spare dash pad and should have sunk my ScanGauge in the top of it. There has to be a clean way to mould something in the vinyl of the dash pad.
Old Sep 29, 2013 | 10:25 AM
mudpie's Avatar
Exhaust gas temp
Old Sep 29, 2013 | 11:50 AM
gdog's Avatar
Pics please! Want to see how you squeezed 3 gauges into one din. Assuming at least one of them was smaller than 2.0623" diameter?
Wait, just added it up, it would be tight but 3 should fit. Would still like to see what you did..
rspi
Jan 1, 2014 06:28 PM
chadman551
Nov 9, 2009 11:16 AM
lxwvandenberg
Jul 15, 2009 03:47 PM
bli745
Oct 31, 2006 04:02 PM
KNIN
Apr 27, 2005 07:23 PM
