volvo 850 instrument cluster gauges dont work
Old Nov 7, 2009 | 06:11 PM
chadman551's Avatar
Default volvo 850 instrument cluster gauges dont work
I was driving my volvo 850 today and all the gauges were working fine until i stopped to get gas and air and then i started it again and only the boost gauge worked os can someone help me and tell me what the problem could be?
Old Nov 7, 2009 | 08:18 PM
mhutchens's Avatar
There is a fuse for the gauge cluster in the fuse block but the power also routes through "Overload Relay #2". If it isn't the fuse, try the relay. If it isn't either than there may be damage internal to the instrument panel (there is an internal fuse and a couple of voltage regulators).
Old Nov 8, 2009 | 08:40 AM
Psaboic's Avatar
Do the instrument cluster lights work? If not, it might also be a loose connection behind the cluster.
Old Nov 8, 2009 | 08:49 AM
chadman551's Avatar
yes the lights work on the instrument cluster, and i was driving it last night and the gauges kept jumping around and worked sometimes and didn't work sometimes and i dont know what the problem is?
Old Nov 9, 2009 | 11:16 AM
fcpgroton's Avatar
Former Sponsor
If your car is a 94 - 95, you can check the cluster codes by putting the wire in A7 under the hood. Here is a list of all the codes.
850 Codes
If you scroll down the list, you will see the A7 codes.
WrenchTurnerDave
Jun 16, 2014 08:15 AM
crazypenguins
Jul 10, 2012 12:52 PM
volvo5volvo
May 29, 2012 05:46 AM
siuc_gator
Nov 3, 2008 04:28 PM
bli745
Oct 31, 2006 04:02 PM
