Gear Indicator Lights
Old Feb 21, 2010 | 06:16 PM
91shelby's Avatar
Default Gear Indicator Lights
The gear indicator lights arent working on my 850 how do you gain access to the lights or what would cause them not to work?
Old Feb 21, 2010 | 06:19 PM
I bet the bulb is bad. You need to remove the center console to get to the bulb.
Link to the instructions for the console. https://volvoforums.com/forum/showth...314#post161314
Old Feb 22, 2010 | 12:24 PM
scousa's Avatar
Just bought my son a '93 and that same light was out on it - $8 bulb from the dealer. Might as well replace the cigarette lighter bulb while you're at it - same bulb.
Not really too difficult to replace after taking the center console out. Only problem I had was the housing of the new bulb wasn't tight and given the lack of room even after removing the console it wouldn't fit into place. I ended up disconnecting the piece that the bulb connects to that spreads the light to the gear selector settings. With that out I could easily squeeze the bulb housing to get the bulb in place - but it was frustrating.
Ian
Old Feb 22, 2010 | 02:48 PM
JimKW's Avatar
My one car has been out since I bought the car. I know when I'm in reverse and if I'm not in drive and going forward there is an arrow that lights on the dash. Not worth the trouble just to replace a bulb.
Bolbo
Aug 22, 2013 07:41 AM
ctodd97
North East
Jul 2, 2012 08:41 AM
walthevolvoguy
Jan 3, 2012 12:55 PM
jasongood
Jan 8, 2009 08:48 AM
alldwayray
Jan 20, 2007 03:18 PM
