Headlight wiper troubles
Old Nov 4, 2012 | 08:26 PM
'93GLT's Avatar
Default Headlight wiper troubles
Hi, I'm new to the site, so sorry if this has already been answered, but my driver side headlight wiper will not work. The passenger side works fine, but i only get a strange clicking sound from the drivers, as if it might be jammed or blocked. Can anyone help me, or is there any more critical information that I must include? Thanks!
Old Nov 4, 2012 | 10:15 PM
'93GLT's Avatar
Also, anyone know where i can get the factory classic green paint?
Old Nov 5, 2012 | 07:26 AM
You can get the paint from the dealer or any good auto paint store.
You will likely have to replace the wiper motor. You may want to get one from a salvage yard, not sure how you would test it but most salvage yards will give a 30+ day warranty.
Old Nov 5, 2012 | 11:54 AM
klausc's Avatar
The easy solution is to unplug the wiper, the plug is between the headlight and radiator and usually an orange plug.
In most cases, salt got into the wiper motor shaft and corrosion caused it to stop rotating. Pulling off the motor is a most difficult task.
Old Nov 7, 2012 | 02:26 AM
Brick850's Avatar
If it is the left one that is the problem, it is the easiest one to get out. They are renown for failure, get one that work from a junkyard. Occasionally they are on eBay too.
KS70T5M
May 10, 2010 07:52 PM
Swish
Apr 10, 2006 09:01 PM
tsunami
Mar 23, 2006 09:29 AM
robert213
Dec 11, 2005 03:09 AM
floryed
Apr 13, 2005 01:31 AM
