Heater/AC fan not working
Old Nov 17, 2012 | 10:48 AM
'93GLT's Avatar
Default Heater/AC fan not working
Does anyone have an idea what could be wrong, like the fan motor?
Old Nov 17, 2012 | 11:08 PM
What's going on? You really need to describe the problem.
Old Nov 18, 2012 | 09:55 AM
'93GLT's Avatar
Well, when i put the key in the ignition, and turn it to where the dash lights come on or when i start the car, the 'REC' and 'AC OFF' buttons blink for like 30 seconds, and when i adjust the speed of the fan, there is no response...oh, and sorry that i wasn't very descriptive in the post above.
Old Nov 18, 2012 | 10:58 AM
Does the fan work on any speeds?
Old Nov 18, 2012 | 06:38 PM
'93GLT's Avatar
No, it does not.
Old Nov 21, 2012 | 05:54 AM
I would check fuses, if they are good pull it and put 12V to it to see if it kicks on. Be careful because they jump if they work. If it doesn't work you'll have your answer.
http://atthetipwebs.com/technologyin...or_removal.htm
Old Jul 26, 2013 | 06:42 AM
If the fan works, you likely have 1 of 3 problems:
1. Bad climate control box.
2. Bad relay (105) at the fuse box.
3. Bad resistor.
Is your system ECC or MCC? ECC has numbers on the temperature dials.
Old Jul 30, 2013 | 03:32 PM
Pull the fan and put 12v on it to see if it comes on then.
Old Jul 30, 2013 | 03:33 PM
'93GLT's Avatar
Default RE Blower Motor
This is my blower resistor. Are there any visible faults?
Attached Thumbnails Heater/AC fan not working-mason.jpg
rat62
Dec 9, 2013 02:11 PM
tjc61
Apr 19, 2013 02:18 AM
emp69
Nov 19, 2011 07:25 PM
BigAdam
Oct 21, 2008 10:01 AM
eschroder
May 11, 2008 05:29 PM
