Heater fan issue
Old Feb 20, 2019 | 09:11 PM
Phil 850's Avatar
Default Heater fan issue
I think this is related to all the rain we have had recently but first My heater fan wouldn't turn on and now it wont turn off. Any ideas on a cause for this? I'm wondering if water got into the ecc unit and is shorting something out.
Old Feb 21, 2019 | 03:56 PM
can you select speeds or is it stuck on high?
Old Feb 21, 2019 | 08:45 PM
Phil 850's Avatar
Now it does nothing and the lights by the AC and circulation switches don't come on. I got nothing and its cold, thank goodness for seat heaters. Help
Old Feb 24, 2019 | 04:43 PM
Phil 850's Avatar
Today I checked all related fuses and all are good. When I turn on the car the red light that is supposed to come on by the AC switch does not come on and some times the fan comes on when the fan switch is off and sometimes nothing happens. I pulled out the climate control unit to check connections and all was good. I have power to the unit since the fan sometimes runs. It looks like I need a new climate control unit. Is there any where that sells reconditioned units? I might try PnP but then I could just be buying another bad unit.
Old Feb 25, 2019 | 04:33 PM
I would go the PnP route or search eBay. the units don't die all that often and you can probably find one via car-part.com, eBay or Craigslist for $75 to $100 tops.
Old Feb 25, 2019 | 09:15 PM
Phil 850's Avatar
If I have to pay $100 I can get a fully reconditioned unit for $125 from Programma. If its not raining this weekend its off to PnP.
Old Aug 31, 2019 | 02:48 PM
Phil 850's Avatar
Well I finally got to PnP today and picked up a ECC unit. Now I get a reaction from the various components but the fan still wont run. Is there anything between the ECC and the fan like a speed control or anything?
Old Aug 31, 2019 | 03:22 PM
fan has a ballast resistor to control the speed - but that should be bypassed when on high. did you probe around the relay to see if you get any voltage?
Old Aug 31, 2019 | 05:24 PM
Phil 850's Avatar
Is that relay in the fuse box under the hood? If it is not there then where is it? If everything else is reacting then a relay makes sense.
higgy baby
2001-2013 model year V70
Jan 12, 2018 04:03 PM
basha53
Jan 14, 2012 10:18 AM
bryanindenver
Oct 30, 2008 07:00 PM
GMad
Oct 29, 2008 09:57 PM
air force rascal
May 31, 2008 05:07 PM
