Help! i want an intake!!
Old Jun 26, 2008 | 03:11 PM
gotlove4myvvo's Avatar
Default Help! i want an intake!!
Of course i have a 1997 850, which kandn does'nt make an intake kit for. I have searched the web for ideas, but have come up dry. I read an article about some fellow in australia making his own intake, sort of. Here's what he did: He removed the old intake hose from his airbox and routed 100mm hose throught the trand oil cooler pipes and around the front a/c condensor so it gets the ram air effect under the bumper. Something about this seems odd, plus responses to his post posed the question "what happens when you his a large puddle?" since the hose will be about 10 inches off the ground, i could see this being a problem. Here's a link to what he did if anyone is intrested. http://www.matthewsvolvosite.com/airbox.php
anyway, if anyone has any solutions for me that would be great!!
Old Jun 26, 2008 | 04:11 PM
S70driver's Avatar
Default RE: Help! i want an intake!!
Ok are you turboed or N/A?
If your turboed you have options. Have you even searched for Volvo intakes other places? If not you need to look at this thread that I have linked below.
https://volvoforums.com/m_38606/tm.htm
For turbocharged models IPD USA, EuroSportTuning, BMC CDA all make intakes for the 850. Also if you can find it Pipercross makes them for the Volvo's.
If your N/A you have the option to custom make one. Same goes for the turbo model if the premade ones don't suffice for you.
Stefan1235
May 21, 2011 09:00 PM
rquinonez32
Sep 30, 2008 02:08 PM
DJRUZERS6
Mar 2, 2008 03:09 PM
shelbylay
Oct 23, 2007 07:57 PM
JBVolvo
Apr 6, 2007 10:17 PM
