Hesitation when going WOT...
Old May 15, 2012 | 08:59 AM
Dimi850T-5's Avatar
Default Hesitation when going WOT...
Hi, recent owner of a fantastic auto 850 T-5 with 140 xxx kms. The car was well maintained by two senior owners bumper to bumper. Out of curiosity, i get on the highway and floor it... What happens is, it coughs before inputing all of its power. Why is this? Filters? Turbo... *hopefully not*.. Do suggest something, please.
Thank you.
Dimitri.
Old May 15, 2012 | 09:14 AM
When was the last time plugs, wires, rotor, cap, pcv, fuel filter, etc., were changed?
Old May 16, 2012 | 12:06 AM
SteveMontreal's Avatar
I agree, esp plugs. Get original volvo and make sure of the gap. Older 850 like fresh plugs, cap and rotor more often than the manual suggests. Vacuum lines get dry and crack a lot too. If it runs smoothly through moderate acceleration with a nice punch to it, the turbo is probably ok.
Have you checked out the 850 new owners thread on here? Lots of good advice about what to check as far as what work may neef to be done?
I have a 96 platinum high pressure turbo - love it! Although its on its last legs...
Old May 16, 2012 | 03:00 AM
volvoguy23's Avatar
Just needs a tune up man.... Usually the hesitation is the old plug wires but you still want to do a full tune up, and you should be fine.
Old May 16, 2012 | 03:03 AM
volvoguy23's Avatar
Just needs a tune up man.... Usually the hesitation is the old plug wires but you still want to do a full tune up, and you should be fine. Make sure and use ORIGINAL EQUIPMENT!!!!! Fcp groton and ipdusa will usally have what your lookin for.
Old May 16, 2012 | 05:24 AM
Oh, one more thing to check. These cars have a hidden problem with the turbo intake tubes, when they get old, they get a little soft, when they get a little soft, they sometimes collaspe under WOT. You can see it by starting the car, opening the hood, pumping the throttle and watching the intake tubes. I seen a video once where the guy was making his intake tube collaspe when he reved his engine.
Old May 17, 2012 | 12:01 AM
Rspi / happened to me on my plat. More likely with the high pressure turbo, too. This usually causes a feeling of having a rev limiter on the car, tho. It kick great on the boost, but then flatlines when the hose collapses, like a govenor.. Very strange sensation, lol
Sean Logan
1998-2000 model year V70
Aug 1, 2013 05:33 AM
kyvahe
Jun 25, 2009 08:04 PM
Cobra_03
Jan 31, 2009 10:04 AM
hispeed
Apr 9, 2008 05:31 PM
