hi newbie needs help
Old Oct 12, 2009 | 04:04 PM
lou's Avatar
lou
Default hi newbie needs help
hi all we bought a volvo 850 2.5 none turbo 10v and its drinking oil and when we stop and then pull away we have blue smoke coming out the back, then it clears, had the engine block tested and there's no problems, the water is holding in the system, there's no oil leaks and we have used 1litre of oil in 2days. hope some1 can help us out
lou
Old Oct 13, 2009 | 12:33 AM
TIPSP's Avatar
Got Boost?
any leaks you can see? that is a lot of oil in 2days.
Old Oct 13, 2009 | 03:27 AM
lou's Avatar
lou
no leaks at all
Old Oct 13, 2009 | 07:28 AM
JPN's Avatar
JPN
Make sure the oil is not over-serviced.
Make sure the PCV is in good condition.
Make sure to use the OEM filter (MANN).
What oil have you been using? As a temporary remedy, try using heavier weight oil, such as 10W-40. If blue smoke is spitting out of the tail pipe, oil is still entering the combustion chamber somehow. Strange.
If the oil level is correct and the PCV is not too hideously faulty, I would have the engine for compression-tested again at another reputable shop, even if the coolant reservoir level has not dropped and there is no sign of fuel in there.
JPN
Old Oct 13, 2009 | 08:53 AM
lou's Avatar
lou
hi service light is on and it needs a service, oil used was castrol high millage £5.98 ltr.
Old Oct 13, 2009 | 10:08 AM
fcpgroton's Avatar
Former Sponsor
Being this is a non-turbo, there has to be oil getting in somewhere. Did you have the engine compression checked? If so, what was the numbers?
Old Oct 13, 2009 | 10:52 AM
lou's Avatar
lou
hi there, car-going into garage thurs, and no not had compression test done as yet. what readings/figures are we looking for on the compression test to tell us it ok, and i take it they should be reading around the same figures.
Old Oct 13, 2009 | 07:50 PM
TIPSP's Avatar
Got Boost?
They should all be about the same. I forgot the range, but if two or three are different by a good amount, then It is probably going to need an opening. piston rings, valve seats leaking....etc. wait for tech to say something...
Old Oct 13, 2009 | 08:37 PM
Johnny Mullet's Avatar
If it smokes that bad and it's not leaking, I would guess it needs a bottom end rebuild. Especially since it's a non-turbo.
Old Oct 14, 2009 | 06:43 AM
lou's Avatar
lou
thanks for the advice guys, will c what the garage has to say in morn.thanks again.lou and andy.
MntnDewMan
Dec 5, 2012 08:06 PM
79lilred
Nov 25, 2008 09:30 AM
dariustrucker
Feb 16, 2008 07:52 PM
xmoke
Oct 17, 2005 02:31 AM
jesselou
Apr 22, 2005 06:42 PM
