High rev on start
Old Dec 11, 2008 | 11:56 PM
kgolsan's Avatar
Default High rev on start
I'm looking to purchase a 94 Turbo wagon that the owner claims revs to 3K rpm on COLD or WARM start for just a few seconds, then settles to normal idle. I dont know much more. 135K miles on the wagon. I havent driven to determine if the rev issue hampers performance elsewhere in the drivability. Any help would be appreciated
Old Dec 12, 2008 | 07:39 AM
Default RE: High rev on start
When first started it will raise some but 3k isn't really normal. See if the check engine light is on.
Old Dec 12, 2008 | 08:14 AM
Psaboic's Avatar
On mild days ours revs to about 1800 to 2,000 RPM for a couple seconds. On cold days (40 degrees or below) it will rev to about 2300-2500 or so for a few seconds and then settle to a normal idle
Old Dec 13, 2008 | 09:40 AM
JPN's Avatar
JPN
In the freezing winter in Chicago, the fast idle does reach close to 3,000 RPM then after a few seconds it comes back to 850 plus minus. But if Tech says it is not normal, then....
JPN
Old Dec 13, 2008 | 09:46 AM
It might be close to that in the really cold weather. The coldest we get here is about 32 degrees.
Old Dec 13, 2008 | 02:58 PM
litehwk356's Avatar
mine revs high here in michigan where it has been like 15 degrees or so the past couple of days, probably around 2500 to 3000
Old Dec 13, 2008 | 08:47 PM
wheelsup's Avatar
LOL sounds like it's normal...but tell the owner it's a problem and will cost XXX to fix and lower the price by that amount
Old Dec 14, 2008 | 10:35 AM
Psaboic's Avatar
+1 <grin>
Syukri Dhm
May 22, 2012 07:02 AM
yobea
Sep 27, 2007 03:16 PM
pconfar
May 10, 2007 04:35 PM
naughtyvolvo
Jun 19, 2005 01:37 PM
rustexpert
Feb 26, 2005 06:06 PM
