Removing Auto Shifter Cable...
Old Dec 14, 2008 | 03:11 PM
ludeless's Avatar
Default Removing Auto Shifter Cable...
I'm getting around to working on the 5 speed shifter swap part of the project, but i'm stuck on how to remove the automatic shifter. I've got the shifter box free from the console, and have pulled the cable all the way through the firewall into the car already, but can't snake it all the way through b/c the metal bracket that bolts to the trans is too big to pass through. Is there a way to remove the part at the very end to get the bracket off?
Or is there a way to separate the cable from the shifter itself? I'm looking all over it but can't see where it would detach...
Old Dec 14, 2008 | 08:11 PM
Default RE: Removing Auto Shifter Cable...
Yes the cable just slides into a groove in the shifter assembly. You will lift the cable straight up to get it out. Then feed it from inside to the outside.
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
msdisk
Dec 14, 2007 05:36 PM
danielribo
Jan 22, 2006 12:32 AM
