Hissing AC after car shut off
Hi everyone. I recently bought a 95 volvo 850 wagon. The previous owner acknowledged that there were air conditioning issues. The compressor was shutting on/off so I jumped the low pressure switch, checked R pressure and added a can. Now the compressor runs solid and the air is cold, so at least there are no other big problems with the system.
however, I realize there is likely a leak somewhere or I wouldn't be correcting the low pressure. The most common place for leaks, the evaporator, was replaced in 2003 according to a sticker under the hood. Perhaps it is leaking again. When I turn off the car after running the AC, I hear a hissing noise for a few seconds coming from behind the passenger side dash area which is where the evaporator is.
Forgive me if it sounds like a silly question, but is that a normal noise or does it indicate that a leak might be at the evaporator? I've never had a car hiss like that so audibly in the interior, but this car is new to me.
My Volvo S60 doesn't seem to do this, but I've only had that for a couple weeks as well
Thanks for any help!
![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Greetings from Narita, Japan.
The hissing is probably all right, as long as the evaporator was actually replaced in 2003. It is probably coming from the expansion valve inside the evaporator and releasing accumulated pressure after shutdown.
Keep the AC running and see what happens within a week, then recheck the system pressure. If the pressure drops, however, I would first inspect thealuminum tubing connections for evidence of leak; you can spot it with a film of oil, asR134a (refrigerant, or more commonly known as Freon)is circulating with the oil within the system.
I hope this helps.
JPN
I hope this helps.
JPN
sounds possible. expansion device/orifice may have clogged with debris after the evap. change. Once a system is opened and allows outside air/moisture to conaminate system, trash often gets in if it is not properly vacuumed. Unless you want to do a full evacuation and deep vacuum pulled, I'd leave it alone if it's working. Your dryer may also be contaminated. If it works, don't fix it as they say. But expect long term issues a few years from now if you still have it.
ORIGINAL: n4hen
tennisguy
05-16-2006 03:13 PM
