How many volts?
Old Nov 13, 2008 | 09:19 PM
suprattracer84's Avatar
Default How many volts?
How many volts should the alternator be putting out on a 1995 850 turbo. Mine is putting out 13.6-13.8 Every once in a while i have to jump start it. I am trying to pin point if its my battery or alternator. Let me know. THanks Danny
Old Nov 13, 2008 | 09:38 PM
Default RE: How many volts?
I have about 14.0 on my car. Check in the cable just before the terminal and see what you get.
Old Nov 13, 2008 | 09:46 PM
That is where i am checking. I dont know. I always thought you should be getting 14.5-14.7 but i dont know for sure.
Old Nov 13, 2008 | 10:31 PM
litehwk356's Avatar
i get 14.8 from mine
Old Nov 14, 2008 | 12:06 AM
14.8 sounds much more realistic. Does anyone know the factory specs on alternator output?
Old Nov 14, 2008 | 06:59 AM
14.8 is almost to high. 14.25 is about where it is supposed to be.
I said check in the wire before the terminal because the connections inside the terminals are going bad. If you get like 13.5 at the terminal itself and 14.0 at the wire before the terminal then the terminal is bad you are loosing .50 volt through the terminal.
Old Nov 14, 2008 | 10:08 AM
JPN's Avatar
JPN
And tell us how old & what brand your battery is. This may help us help you better.
JPN
Old Nov 17, 2008 | 12:32 AM
It is a Interstate battery. Not sure how old but i am guessing about three years. Sorry it took so long for me to get back on. But yeah. Thanks so far for all your help. I still have not had a chance to really dig in and find out whats going on with it. So busy lately. Once i get into it i will post. thanks Danny
Old Nov 17, 2008 | 06:14 AM
JPN's Avatar
JPN
There is nothing to be sorry about.
If you have to jump start it, the battery is not holding charge for whatever the reason. It could be a weak battery (though Interstate Batteries are one of the bests around) or the alternator cannot keep up with the demand under heavy load conditions (rainy nights in hot summer is the worst).
If both are functioning normally, then suspect a parasitic current draw. I once had it with the glove compartment light.
JPN
Turbo Theaters
Sep 25, 2009 08:02 PM
jakefitz
Mar 31, 2009 02:38 PM
diehardgator1
Sep 9, 2008 06:52 PM
1990TURBO740
Dec 25, 2006 04:23 AM
robrike
Oct 19, 2006 09:11 PM
