How much can i tow with the Volvo?
Old Apr 4, 2007 | 08:29 PM
huzzsaba's Avatar
Default How much can i tow with the Volvo?
I may have to do some long distance moving in a few months. Im thinking of using a 5x10 closed trailer.I have a hitch and everything. I would be loading it up with at least 1200 lbs along with the weight of the trailer which is 1250. I will also have another 800 lbs in the car including luggage and passengers. Wil the volvo be able to handle this?
Here is a link to the trailer i am tinking about. According to Uhaul i can pull this as long as i have a class 2 hitch which i believe i have.
BTW its for a 25 hour haul on the highway, and the wagon is automatic.
http://www.uhaul.com/guide/index.asp...t=trailer-5x10
Old Apr 4, 2007 | 08:45 PM
huzzsaba's Avatar
Default RE: How much can i tow with the Volvo?
After searching a bit, Im pretty sure i will have to install a tranny cooler as. I have also read that in order to avoid frying the transmission, I would have to leave it in 3rd gear to keep the temps down? Can someone confirm this? and 3rd gear for 25 hours???
Old Apr 4, 2007 | 10:36 PM
huzzsaba's Avatar
Okay i think i will change my mind and tow something smaller like this one.......
http://www.uhaul.com/guide/index.asp...nt=trailer-4x8
I think i should be fine with this one.
Old Apr 5, 2007 | 12:12 AM
JPN's Avatar
JPN
Hi Ali,
If possible, referto the owner's manual or Haynes/Chilton's service manual for towing capacity. Also, before the trip, double-check on the engine oil, coolant, ATF & brake fluid level & conditions.
Have a safe trip.
JPN
[IMG]local://upfiles/6892/BC37C99FD14D4BF48D9D0E9CFB7EED1F.jpg[/IMG]
Old Apr 5, 2007 | 12:16 AM
westfp's Avatar
The 4x8 looks doable to me, but keep towing capacity within limits. It should be in your owners manual. Good luck.
93' 850 GLT
Old May 29, 2009 | 08:04 PM
Chebucto's Avatar
I plan on towing a pop up trailer with my volvo 850 turbo wagon (20 valve). I noticed he mentioned a tranny cooler in his previous question. My question is " does my volvo already have a tranny cooler installed at factory or how can I tell if mine has one? I know I have tranny lines going into the rad already.
Chebucto
Old May 29, 2009 | 09:06 PM
850tony's Avatar
you do not have one stock, and i dont know of any trans lines going directly to the radiator.... ?!?! *confused*
trans coolers look like mini 8inx11inx1in radiators and get outed off to the side usualy.
Old May 30, 2009 | 06:58 AM
JimKW's Avatar
On the turbo there are transmission lines going into the radiator. Not sure about the non turbo. Personally I would not tow more than 2000-2500 lbs.
Old Jun 1, 2009 | 02:01 AM
zmontgomery's Avatar
I know it may not be totally relevant, but I have a 960 and I towed the same uhaul 4x8 from Montana to California without issue. I definitely had similar weight conditions, and I was able to tow in "D" and go 70mph on flat ground with no issues at all. When I started getting into hilly country "3" and 60 or so mph was no issue at all. I do have a stock tranny cooler though, which probably helped. Since the 850 is FWD and has pretty similar HP, I would think that you wouldn't have many issues.
Old Jun 3, 2009 | 04:32 AM
volvorog's Avatar
Interesting, I just bought (yesterday) an 850 maroon wagon 5 speed, and want to locally trailer a lawn tractor around for some mowing jobs on the side..I dont have a tow hitch yet, but a neighbor who took me to get the mower has a small trailer in his yard,,told him I'd mow his yard as his is in the shop, until he gets his back...I have a new to me 96 volvo wagon, a brand new yardman lawn tractor, 2 miatas and 3 motorcycles......life is good !!!!....Rog
Old Jun 3, 2009 | 12:55 PM
850tony's Avatar
just looked at the specs for a 94 5 speed non-turbo. says its rated at 3,000 lbs...
impster
Jun 6, 2012 02:23 PM
boggy
Nov 4, 2011 08:22 PM
Spyros
Jul 21, 2011 04:38 PM
MattS40
Dec 10, 2010 05:44 PM
aryanvahedi
Nov 18, 2009 08:59 PM
