How Much Would It Cost To Get A Rear Main Seal Fixed on the 850?
Old Apr 7, 2009 | 08:00 PM
STREETFIGHTER50's Avatar
Default How Much Would It Cost To Get A Rear Main Seal Fixed on the 850?
If it's indeed worse case scenario my rear seal, I'm pretty sure it's gonna be a lot from a dealership or shop. Any local techs want a side job? About how much would this be?
Old Apr 7, 2009 | 08:32 PM
Labor is about 9 or 10 hours for doing it. The seal is pretty cheap.
Im not sure of the labor rates in your area.
Old Apr 8, 2009 | 08:34 PM
Johnny Mullet's Avatar
Are you sure it is a rear main seal leaking? Could be a vent system problem if it has a lot of different oil leaks.
Old Apr 10, 2009 | 03:44 PM
mcleantmw's Avatar
At my local independent Volvo repair shop it's about $1000............much more if you use a Volvo Dealer. Make sure you specify what oil you want used when they refill the engine or they'll just put whatever cheap 10-30W regular oil they normally use for oil changes.
Old Apr 11, 2009 | 02:50 PM
fast850r's Avatar
3 years ago I had mine done at local garage in CT and it was $650
Old Apr 11, 2009 | 04:42 PM
Yeah it's definately the rear main seal Went & had everything checked out at one of the local shops in SF.
Thinking of just selling it as is & taking a loss/starting over since I realy want a black interior car anyway. One Volvo tech can do it for $500 over the weekend. I supply the parts. Also I gotta clean out my PCV system out. Everything else checked out good.
oreng
Jul 20, 2010 03:22 AM
STREETFIGHTER50
Jun 5, 2010 05:40 AM
jcmartin
Sep 20, 2008 09:19 PM
1996850turbo
Aug 23, 2008 05:27 PM
Volgrrr
Jul 15, 2006 12:03 AM
