How to remove door window seal
Old Apr 18, 2012 | 03:43 PM
daver80's Avatar
Default How to remove door window seal
on my 850 drivers door I've got rust (the only rust on the car) on the top of the passenger side front door, right under the rubber window gasket. How do you remove that gasket? Does the whole window have to come out? The rust is underneath that gasket, gasket really should be removed before I repair and repaint it. thanks, dave
Old Apr 18, 2012 | 03:46 PM
Hey Dave, it may be cheaper and easier to replace the door. That's my plan. I have seen doors for $50. There is a screw to remove to get the seal out. Step 17 here shows the screw for the rear door, maybe the front door is similar.
Rear Window Removal - Volvo 850
Old Apr 19, 2012 | 09:29 AM
daver80's Avatar
Default window
I have considered that, but the rest of the door is fine, not rusty on the bottom, hinges nicely. The rear passenger door has a couple of small dents. If I can get that rubber strip off it would be easy to just fix and paint in place. My fender is kinda messed up (like that when I bought the car) bought a straight, rust free fender last weekend for 30 bucks at my local U pull it yard (arent those places great?) but once looking into painting technique, I really should paint the fender and both doors, blend back to the taillights. These little projects seem to expand dont they? See photo, not my car, but this is the rusty spot. Dave
Old Apr 19, 2012 | 07:20 PM
That trim just lifts off. I would just scrape the rust off and touch it up with the kit the dealer sells.
Old Apr 20, 2012 | 10:04 AM
daver80's Avatar
Default trim
rspi- OK thats helpfull info, I figured I had to gut the door to get to some annoying pop rivets or something like that. It's a peculiar place for rust to start I think, top of the door? wonder how that started. I'll poke around soon. Gonna prime my fender today! Dave
Old Apr 20, 2012 | 01:16 PM
Scratches are the root of all RUST.
rspi
Apr 13, 2022 01:45 PM
nasko00v40
Mar 19, 2013 06:03 PM
Jetstreamer
Jun 14, 2012 09:32 PM
UlgaDenVolva
Apr 14, 2012 02:38 PM
robdenmick
May 8, 2011 02:57 AM
