How to reset the SERVICE LIGHT on the '93 through '95 models...
If you have a 1993 through 1995 SERVICE LIGHT that comes on when you start the car and goes out after the car has been running for 2 minutes, you can likely reset it with these instructions.
You can see more on reseting service lights here: http://volvospeed.com/850slight.php
Here is a video:
- Turn the key on - II position (car NOT running).
- Open the hood and pull the cap off the OBD-I, A (left side) adapter.
- Remove the jumper wire from the cap and Jump #7.
- Push the button 4 times. Each time you press the button, the red light next to it will light up. Each time you release the button the light will go out. After you let it go the last time, wait a few seconds and the red light will come back on and stay on.
- While the light is still on, push the button 1 time. Wait a few seconds until the red light comes back on.
- While the light is on, push the button 5 times. Wait a few seconds until the red light comes back on.
- While the light is on, push the button 1 time. The red light will flicker several times then go out.
- Remove the jumper wire and cover the connector. You are done.
Here is a video:
fathcoltged
2001-2013 model year XC70
Apr 30, 2015 07:10 AM
Thundar2247
Sep 21, 2008 05:14 PM
