Infamous transmission clunk into reverse.
Old Jan 17, 2014 | 06:39 PM
2012's Avatar
Default Infamous transmission clunk into reverse.
Well, I've read quite a bit on this, but I'm curious to see what your experience has been when an 850 turbo makes a harsh thump while shifting into reverse. I know I'll get scolded for this but the fluid is sitting almost an inch high on the dipstick when hot, but I haven't been able to get it drained just yet. Could this lead to the thump? It's actually more of a bang. Thanks for your thoughts on this
Old Jan 17, 2014 | 06:54 PM
Fogducker's Avatar
Have your Universal joints on the drive shaft checked.... ;-)
Old Jan 17, 2014 | 08:57 PM
The CV joints in the front shafts could be the problem as sometimes they will make a more noticeable noise going in one direction than the other but usually they will click and more when turning. What you describe would be something more common to an all wheel or rear wheel drive with a drive shaft and actual "U" joints.
You should also check your motor and trans mounts. The upper mount on the firewall offset a little toward the driver is know to work it's way out and that could also cause a bang when shifting.
mcaanda
Jun 28, 2010 07:00 AM
summit
May 18, 2009 01:41 AM
geofftucker
Jan 1, 2009 08:21 AM
Toxicity
Nov 21, 2007 04:00 PM
