Insatlling powered seats
There is wiring you will have to do if the powered seat harness is there. If the powered seat harness is not there since you have manual seats, you probably won't be able to because the memory part of the seat is wired into a computer/diagnostics system. I tried different harnesses to make a power S70 seat work in my passenger manual seat and I could not get it to work.
My manual passenger seat did not have have the harness there for the powered seat option, so they're not all prewired. Luckily, I was able to cut out the plug from my wagon which had power seats, but even using the plug and a constant 12V power/ground, I was still unable to run the power seat.
HelgaTheS80
03-20-2007 03:09 AM
