Installing Blower Motor - and Resistor Question
Old 11-23-2007 | 06:48 PM
Evo 850's Avatar
Default Installing Blower Motor - and Resistor Question
Hey everyone,
After reading through the tons of threads regarding blower motors & resistors going bad ( I have a '93 GLT w/ ECC with the blinking REC/AC orange lights), I have another question regarding getting this car to finally work right.
I installed the new blower motor, and putting in the new blower motor seemed odd; the prongs on the new blower motor need to go into the female prongs in the black plastic housing, but how? I thought the only way was to brake the plastic off around the prongs, and then just get the two to connect. Seems like it should work fine. (so I did this..)
Still, no air coming through the vents, so I'm assuming the resistor is bad also.
I found this one on ebay, and can't figure out if this will work..
http://cgi.ebay.com/ebaymotors/Volvo...spagenameZWDVW
Thanks for your helP!
Old 11-24-2007 | 02:05 AM
info2x's Avatar
Default RE: Installing Blower Motor - and Resistor Question
Groton only has one listed on their website so I guess it is the same across all years.
[align=left] [/align]
Old 11-24-2007 | 09:02 AM
99VolvoV70's Avatar
Looking at eEuroparts, the part number for the '93 850 is 9144354 and for the '96 850R as listed on eBay is 9134932. The pictures do look very similar but the part numbers are different. I wouldn't risk the $12 (assuming there aren't any other bids), but that's up to you. For the record, here's the part on eEuroparts ($129.90, a lot more than the used one on eBay): http://www.eeuroparts.com/productdet...&code=7671
Old 11-24-2007 | 12:04 PM
Evo 850's Avatar
Thought I got lucky for once.. lol
Thanks for the replies.
Old 11-24-2007 | 12:07 PM
info2x's Avatar
9144354 is what is listed on groton.
and looking in VADIS it has them both listed based off of chassis numbers.
Old 11-24-2007 | 02:16 PM
Evo 850's Avatar
hmm, so do you think its worth a shot to save $100 ? I placed a bid on it anyways..
Old 11-24-2007 | 06:25 PM
info2x's Avatar
Meh... you could argue it either way.
I'm a fan of new OEM parts for most things just because then I know exactly what I'm getting. I'm also no wiz with electronics so I tend to stick with I have unless someone can verify for me that it really doesn't matter.
itsneddy
06-19-2013 04:04 PM
jmallie
09-17-2009 10:47 AM
Evo 850
12-06-2007 02:51 AM
Quick Reply: Installing Blower Motor - and Resistor Question
