intermittent Dash Light Failure
Old Jun 24, 2009 | 12:42 PM
dflynt's Avatar
Default intermittent Dash Light Failure
My dash lights went out a few weeks ago and I am having trouble tracking down the culprit. It seems to be just the gauge lights, radio lights (minus the frequency display), and computer light. I checked the fuse and it is intact. Today I drove drove to work and when I arrived at work the lights were intermittantly sort of flashing on and off. Any thoughts on what the cause could be?
Old Jun 25, 2009 | 07:45 PM
Usually it is a bad dimmer switch
Old Jun 26, 2009 | 08:05 AM
Psaboic's Avatar
Dimmer switch
loose (not bad) fuse
loose connector
(in that order of probability)
Old Jun 26, 2009 | 08:48 AM
dflynt's Avatar
Thanks for the help. Any idea how to get the dimmer switch out? I was able to pry out the switch below it, but, I can't seem to get the dimmer out.
Old Jun 26, 2009 | 01:22 PM
850tony's Avatar
wiggle wiggle
Old Jun 26, 2009 | 07:37 PM
It is a pain sometimes. I have a long angle pick I use to pull it out.
Old Jun 26, 2009 | 09:35 PM
850tony's Avatar
assuming im replacing the switch for sure, i take a smaller ish flat tip and put it in the front of the switch, put a lil tension on it and wiggle it around.
BPATR1CK
Dec 17, 2011 07:30 AM
jg1
Mar 16, 2009 08:08 PM
kosmoscanyon
Dec 16, 2008 12:39 PM
jcmartin
Nov 7, 2008 11:14 AM
