jeseus christ on the code cross...help!!
Old Jan 2, 2007 | 10:22 AM
dannydoo's Avatar
Default jeseus christ on the code cross...help!!
i HAD SOME SYMPTOMS WHERE THE CARS fuel relay was sticking and i would hear ir,it wouldnt start untill 10 miutes of playing w/the key back and forth.
Now that has stopped recently but it keeps stalling like its getting no fuel.I put my finger on the relay while it bogs out and stalls,but the relay seems ok...
I got codes A1
114
A2
121
A3
211
222
213
214
241
142 then they wouldnt come back....but 444 and 144 kept repeating.
i got a 124,114,113 from somewhere too?
help!!I dont know where to start!
Merry holidays and happy new years people!
Hope u have a better start than me!
dAN
Old Jan 2, 2007 | 04:27 PM
JPN's Avatar
JPN
Default RE: jeseus christ on the code cross...help!!
Hello Mr. Dannydoo,
The title on your thread made me think you actually saw Jesus standing on the diagnostic terminal.
Anyway:
>I got codes A1(Transmission)
114: Program selector open circuit or short circuit to supply.
↑Probably a loose, damagedor dirty wire/connector to the econ/sport switch.
>A2 (Fuel Control)
121:
→For Fenix 5.2 (10-valve non-turbo engine): MAP sensor signal absent or faulty.
→For Motronic 4.3 (20-valve turbo engine): MAF sensor signal absent or faulty.
Motronic 4.4 is used for 1996-1997 on B5254 S engines and is similar to Motronic 4.3.
>A3 (ABS Control):
211: LH front wheel sensor, no signal when moving off.
222: RH front wheel sensor, no signal from ABS system.
213: LH rear wheel sensor, no signal when moving off.
214: RH rear wheel sensor, no signal when moving off.
241:Not found (try the on-line link you find somewhere on the 850 threads).
142: Faulty stop light switch, open/short circuit.
144:Brake disc overheated (cars with TRC only).
444: No power supply to hydraulic modulator valves.
↑It is extremely unlikely that all these sensors have failed, unless youfell offfrom a cliff/drove into the ocean, so it is most likely a faulty ABS module, notorious for Volvo's and the mfg (either Volvo or ATE) should replace them free in my opinion. By the way, the module is made in ......
Hey! 850 has 100 diagnostic features (exaggerated) so please specify from which socket you got those codes! Even power seats & instrument clusters have bloody diagnostic codes!
http://www.volvospeed.com/maintence.htm
Not to worry, I worked yesterday and my boss used me free for an hour, rats.
Happy New Year,
JPN
nightojnr
2001-2013 model year XC70
Dec 29, 2014 01:04 PM
kwizman
Oct 19, 2013 05:25 PM
johnrpatton
Apr 2, 2008 07:39 PM
crafty
Mar 8, 2006 02:36 PM
tomeldan
Feb 15, 2006 05:35 PM
