Key won't turn ignition anymore??
Old Aug 22, 2015 | 08:16 AM
Pauls850's Avatar
Default Key won't turn ignition anymore??
Hey guys,
Recently I want to shut off my 94 850 and suddenly the key wouldn't turn off, I looked online and it said it was either the shifter or shift lock overide but both were perfect up so I gave the key a bit of force and the turn did go to the off postion however know when I go to use it this morning the key won't turn at all?? It's stuck in the off postion, how do I get this fixed?
Old Aug 22, 2015 | 08:22 AM
Pauls850's Avatar
Old Aug 22, 2015 | 08:24 AM
Pauls850's Avatar
Old Aug 22, 2015 | 08:46 PM
Zenoxen's Avatar
Are you 100% sure that the lock is fine? Sometimes they look fine and there's a tiny part out of place, and that's enough for the key not turning.
Hope I'm not stepping out of bounds, I'm kinda of a noob in the whole mechanic stuff.
Old Aug 24, 2015 | 07:34 AM
dorvin's Avatar
I've had a similar issue before, I had to try to turn my steering wheel while attempting to turn the key.
Old Aug 24, 2015 | 01:51 PM
scirocco's Avatar
i had a similar issue, i could turn the car off but i couldn't turn the key to the lock position to remove the key. the key was stuck in the ignition. I checked the cables for the shifter under the center console and it was filthy. After wiping off the dust, old lubricant and what looked like spilled soda/coffee, i resprayed everything with a silicone lubricant and moved the shifter from Park and selected all the gears several times and that solved the problem. It was so gummed up, the linkage must not have been in sync with the ignition, basically, the ignition didn't know the car was in park, allowing me to remove the key.
Old Aug 24, 2015 | 08:14 PM
Pauls850's Avatar
Old Jan 18, 2016 | 03:55 PM
Clarence Miller's Avatar
It seems as if your lock tumblers are worn to the point that they are no longer "clicking" when you insert and try to turn the key. It's these same tumblers that give the key that "hard to remove" feel.
Old Jan 20, 2016 | 11:30 PM
Might not hurt to spray a lubricant into the cylinder to see if you can free up the cylinder. Nothing to lose.
Old Jan 20, 2017 | 07:42 PM
Pauluk's Avatar
Default Key turn to 1 on ignition and stuck there
I have Volvo S80 2005. If its happen the ignition key to turn only to 1 and stuck there.
i just remove the plastic and hit the ignition metal with a hammer tenderly couple of times and yeeeeee it was turning than .
i safe 300 pounds.
phil.crawford1
2001-2013 model year XC70
56
Aug 2, 2024 04:06 PM
selenims40
Nov 22, 2014 12:47 PM
Rvillev70
Sep 2, 2009 06:57 PM
lexusdave
Apr 21, 2009 07:56 PM
gary2
Jul 21, 2008 05:53 PM
