largest tire size
Old Jun 2, 2009 | 01:54 AM
850tony's Avatar
Default largest tire size
how large can i go in tire width with stock rims and stock setup? stock is 195, can i go all the way to 215? or is that to far?
thanks!
Old Jun 2, 2009 | 03:42 AM
litehwk356's Avatar
i was running 225/45 on mine when i had it, but it rubbed a bit on turns, and it was a bit of a tight fit on the rims. so i would say 215/50 would be a safe bet
Old Jun 2, 2009 | 06:40 AM
JimKW's Avatar
On the 17" wheels the manufacturer calls for 205/45/17 and I run 215/45/17's just fine. On the 15's I run 195's.
Old Jun 2, 2009 | 10:20 AM
bestharry's Avatar
I am running 195/65/15 on mine although 195/60/15 is recommended. The bigger size gives a little smoother drive at a cost of rubbing inside the liner on sharper turns. I will switch to recommended size on next tire replacement.
Old Jun 2, 2009 | 11:30 AM
JimKW's Avatar
Wow a 25" wheel? Don't know if I have ever seen one that big.
Old Jun 2, 2009 | 01:04 PM
850tony's Avatar
^^ i was thinking the same thing. nice typo.
thanks for the info guys!
Old Jun 2, 2009 | 02:40 PM
bestharry's Avatar
Appologies for the Typo Error....and thanks for pointing it. Its corrected now :P
Old Jun 2, 2009 | 03:05 PM
850tony's Avatar
its ok the other day i put calender instead of cylinder haha
hayn5-0
Jun 19, 2011 08:43 AM
JTapper
Mid West
May 27, 2009 07:04 PM
HummerGuy
Oct 10, 2008 08:02 AM
solo25
Jul 22, 2007 07:07 PM
AaronD81
Dec 7, 2005 09:34 PM
