leaking oil
Old Jun 18, 2007 | 09:59 PM
glt93's Avatar
Default leaking oil
Old Jun 18, 2007 | 10:15 PM
glt93's Avatar
Default RE: leaking oil
Solately i have been going through a lot of oil thought it was a leak but nope so finally i deciede to look in the spark plugs walls and what do i find oil on top ofcam cover what could be the problem [align=right][/align]
Old Jun 18, 2007 | 10:24 PM
info2x's Avatar
My bet is a clogged PCV system
[align=left] [/align]
Old Jun 19, 2007 | 08:50 AM
glt93's Avatar
What is the PCV system
Old Jun 19, 2007 | 10:11 AM
RedTurbo850's Avatar
Positive Crankcase Ventilation System. It allows pressure to not build up. If you have too much pressure, your rear main seal could pop out, and then it becomes a major PITA.
Old Jun 19, 2007 | 11:44 AM
JimKW's Avatar
That would be my quess also. I've got the kit to do my PCV System, but have not got around to it yet. Looks like about three hours worth of work for me. Have to take the intake manifold off to do the job.
Old Jun 19, 2007 | 11:57 AM
glt93's Avatar
is it hard to correct
Old Jun 19, 2007 | 02:05 PM
JimKW's Avatar
It looks to be somewhat difficult. You have to be fairly mechanical to start pulling off your intake manifold. I'm not a mechanic by any means, but I feel I can to this job myself, because I worked with my son in law when we took the head off.
Old Jun 20, 2007 | 01:45 PM
white out's Avatar
Definatly the pcv system. I would replace it as quickly as possible. Oil will push out seals and destroy them to get the pressure out. Luckily for you the oil fill cap vented first. My car's rear main was the victim from my pcv going out.
You have to take off the intake manifold to replce the pcv system. It isn't too difficult of a job, just time consuming. It took me about 4 hours.
Nick
Old Jun 21, 2007 | 10:23 AM
glt93's Avatar
After the intake manifold is off what do i do next
Old Jun 21, 2007 | 11:25 AM
JimKW's Avatar
Here is a link to some pictures of what to do:
http://volvospeed.com/vs_forum/index...howtopic=29650
ahilfman
Aug 19, 2010 10:31 PM
supernicguy
Jan 22, 2010 06:21 PM
mercb
Dec 11, 2009 01:49 PM
NCS60
Apr 5, 2007 12:53 AM
MattB850in
Mar 29, 2007 03:55 AM
