Leaking Puddels of Power Steering
Old Mar 16, 2010 | 12:36 PM
matt01's Avatar
Default Leaking Puddels of Power Steering
i am leaking a ton of power steering every time i stop, there is also pressure in the power steering reservoir, it seems to be leaking from the rack or somewhere near the back under the turbo..
what is going on!
Old Mar 16, 2010 | 09:43 PM
wheelsup's Avatar
O-rings in the rack getting old?
Old Mar 16, 2010 | 09:59 PM
matt01's Avatar
probably, but i really need to know if theres supposed to be pressure in the reservoir.
Old Mar 16, 2010 | 10:18 PM
Well if the fluid level is low you are pumping air around causing a pressure build up.
Old Mar 16, 2010 | 10:36 PM
matt01's Avatar
therefore i need to keep it topped up? ok, ok i get it it leaks slowly and when it gets low it fills with air (pressure) and then it creates puddels because of the pressure in the system?
that means i might not have a serious leak.
Old Mar 16, 2010 | 10:38 PM
I will bet the steering rack is bad.
Old Mar 16, 2010 | 10:40 PM
matt01's Avatar
its worth a shot to save me 300$
Old Mar 18, 2010 | 06:45 PM
Cannot hurt.
Siera Hyte
Jul 7, 2012 07:10 PM
x-angel
May 29, 2011 06:13 PM
mdblythe
Dec 21, 2010 08:13 PM
tringa
Oct 13, 2008 02:57 PM
Majki
Jun 10, 2007 12:37 PM
