lots of problems (again)
Old Mar 10, 2009 | 12:24 AM
nonsense619's Avatar
Unhappy lots of problems (again)
'96 850 n/a...ok so even though i try to take care of her shes always sick.i feed her the best (only shell 91 octane).give her preventative and detox meds(seafoamed her through fuel and vaccum induction).and im changing her diaper soon(pvc)..i cant get a break...i have a child due the end of april and need this car in shape..heres her present problems
#1 checked my oil before work this morning and was dangerously low from a slow leak.went to my local quicklube to get a top off but "THEY DONT DO THAT". so i got the whole shabang only about 1k since my last.oh well...pcv job planned in 2 weeks...if my rear main seal is blown what are the dangers of not getting to it right away other than an oil leak?
#2 i also had it scanned and had a code. forget #. something bout too rich in bank one..explains real bad fuel mileage...what i want to know is does this mean bad o2 sensor? or are there other things to check before i spend money?
#3 transmission slipping...im going to try an anti-slip additive.fluid is ok.not due for a change yet.any driving methods i can use to minimize damage? ive messed with the econ/sport button a few times..any incorrect ways to shift between? like should i let go off the throttle before i switch to sport mode?
#4 when i fill up at the pump the needle does not reach the top of the gauge..stays maybe 1/4 inch below the 18 liter mark.havent let the level get low enough to see how long i can be on the empty/red part of the gauge before light comes on.needle moves fine(faster than id like)
help with any of these problems is greatly appreciated..thanks in advance guys
Old Mar 10, 2009 | 06:25 PM
1. Changing the PCV system might make the leak stop.
2. Check for a vacuum leak first.
4. Mine does the same thing. I am thinking it is pretty common.
Old Mar 10, 2009 | 07:06 PM
thanks tech,the fuel gauge doesnt really bother me...about checking for vacuum leaks,wouldnt that make for a lean condition not rich from unmetered air?
i like the new sig. picture...is it not a requirement in florida to have a front licence plate visible? i like the euro plates on the T5-r but like the cleaner look of the white one..thanks again..
and anybody have suggestions about the tranny issue?thanks
Old Mar 10, 2009 | 07:10 PM
Somthngfrce's Avatar
Nope... Thank GOD we don't have to have a front plate here like you do in other states! Otherwise I would have to get rid of my euro plate (nodding!)..
Old Mar 10, 2009 | 07:47 PM
Well a vacuum leak will cause a lean at first but the computer makes it richer seeing the leak but then it will stay rich.
Old Mar 10, 2009 | 07:48 PM
BTW thanks on the Sig!!!
Old Mar 10, 2009 | 10:14 PM
lucky!!!!..lol and i see what you are saying about the vacuum.i will check it out in a week or so(babyshower this weekend)..ANYBODY want to hang out this saturday? lol..
thanks guys
Old Mar 11, 2009 | 06:54 AM
JPN's Avatar
JPN
Any codes for the tranny? Is CEL turned on?
I would first double-check the fluid level & its condition. The fluid should be clear red and must not have burnt smell. If it has a burnt smell, certain internal components (mostly the clutch components) may have burned.
If the fluid turns out fine, then I believe all you can do is to try Lucas fluid. As to driving suggestion, I would not move the shifter between R-N-D whilst the car is still in motion. I would also be easy on the gas (air, to be accurate) pedal until the engine has reached normal operating temp.
JPN
Old Mar 11, 2009 | 10:48 AM
although the fluid is not as clear as new fluid it looks fine to me...no burnt smell or small particles in there...ima buy the lucas today see if it helps
thanks guys
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
Chrispy_T
Oct 7, 2013 04:33 AM
crystalfleet
Jan 16, 2008 07:30 PM
crazydrummer4life
Nov 25, 2007 08:27 AM
bigmayo21
May 30, 2007 12:01 AM
