Loud Knocking at Idle
Old Jul 11, 2006 | 02:45 PM
mragan's Avatar
Default Loud Knocking at Idle
All,
I have an 95 850 Turbo SW with 126K miles. I just started hearing a pretty loud knocking at idle. It does not seem to change pitch or speed or loundess as I rev the engine. It seems to be coming from the top front of the car near the fuel injector rail. Any thoughts?
Thanks.
-Mike
Old Jul 11, 2006 | 07:31 PM
mragan's Avatar
Default RE: Loud Knocking at Idle
Here some addtional inofrmation.
The performance of the car is fine.
I can not hear it when driving.
It soulds like a diesel engine from inside the car at idle.
Thanks.
-Mike
Old Jul 11, 2006 | 09:32 PM
t.d.'s Avatar
Motor mount? Just a guess.
Old Jul 11, 2006 | 10:00 PM
Knocking or Tapping noise?
Old Jul 11, 2006 | 11:31 PM
mragan's Avatar
It is definitely coming from the top front of the motor. More of a knocking that a tapping. Similar to a diesel engine knock and about as loud. There is a little rumble to the sound. At first I thought it was a piece of metal hitting the engine fan. Could it be that the knock sensor is bad and I got a bad tank of gas? I am running 87 octane? Thanks for your help.
Old Jul 12, 2006 | 12:14 AM
mragan's Avatar
Bad news. It was 3 1/2 quarts low on oil! Knocking is a little quiter but still a knocking. I've had a small oil leak for a while but I must have chaged the oil just in time every time before it got too low. This time I drove about 1,000 miles longer before what should have been my next oil change. Live and learn. Would a heavier oil (heaiver than 10w-30) help?
-Mike
Old Jul 12, 2006 | 12:32 AM
Maybe but not much.
Might want to look for another motor.
Old Jul 20, 2006 | 09:24 PM
mragan's Avatar
Knocking is completly gone. Car is running fine. The Oil Idot light never came on but it does illuminate when you first start the car so I know it's not broken. The tempature of the car never really increased either. I think I narrowly escaped a bad one. Now I just need to find out where the leak is. That will be a separate post!
Old Jul 21, 2006 | 03:33 AM
code33's Avatar
Where is this leak at?
Has the PCV system ever been replaced? If it has not, a clogged or poor flowing PCV system will cause excessive crankcase pressure lead to leaks.
http://www.fcpgroton.com/volvo850oiltrapturbo.htm
LOVEvolvos
Apr 24, 2012 10:36 PM
ssvo
Jun 27, 2011 11:54 AM
nedvh03
Aug 3, 2005 09:39 PM
don_pam3352
Jun 11, 2005 04:15 PM
ripleydog
Jan 31, 2005 01:26 AM
