loud ticking
Old Jul 26, 2010 | 03:39 AM
boldtu's Avatar
Default loud ticking
I replaced the turbo on my 97' R Wagon to a 16t recently. Since then I think I hear an exhaust leak. I have not been able to locate a hole anywhere on the exhaust. Does the exhaust have a weak point where the wear out frequently? is there another part that when worn out sounds like an exhaust leak? I have checked and tightened the manifold and turbo bolts, and the engine has been running about 1,000 miles since the turbo swap. The car has 160,000 miles on it.
Thanks,
Chet
Old Jul 26, 2010 | 08:30 AM
boxpin's Avatar
Did you change the downpipe?
Old Jul 26, 2010 | 11:35 AM
vjaneczko's Avatar
You can use a tube from wrapping paper to 'probe' for sounds, or one of those fancy-schmancy stethoscopes. It'll give you a good idea where the sounds come from.
http://www.harborfreight.com/automot...ope-41966.html
Old Jul 26, 2010 | 12:00 PM
boxpin's Avatar
...or a rubber hose that can bend around corners. (deluxe version)
Old Jul 26, 2010 | 04:00 PM
boldtu's Avatar
I got a stethoscope and I will see if I can find it
I did not change the downpipe, it was a straight trade
thanks guys,
Chet
Old Jul 27, 2010 | 04:02 PM
itsmy850's Avatar
I wouldn't put a stethoscope diaphragm against any hot surfaces, though! I am sure it will melt, and ruin the scope. Haha, just a quick 2cents.
Old Jul 28, 2010 | 02:09 AM
boldtu's Avatar
Sure thing! although my automotive stethoscope has a metal rod which is attached to the diaphragm. When I was reassembling the car after the new turbo I do remember that the tubing connecting the turbo to the intake was worn. It looked serviceable but may have been damage when I reassembled. Could this be causing the noise that I think is exhaust? Thanks again for the help guys.
Chet
Captain Zov
Jun 18, 2021 12:01 PM
LOVEvolvos
Apr 24, 2012 10:36 PM
erdal
May 30, 2005 02:51 AM
Ocotillo
Mar 29, 2005 09:14 PM
knight rider
Mar 29, 2005 07:33 PM
