Another weird running issue
Old Jul 27, 2010 | 03:02 PM
ibified's Avatar
Default Another weird running issue
Okay so i got the hose that exploded replaced and installed today. I went to start the car and it started right away, then the idle dropped and the car died. Started it again and the same thing happened. I took it for a quick drive and the idle issue resolved itself.
Also, since i put the new intercooler hose on, the blowoff sounds different. It used to have a flutter sound when it blew off, now its just a "whoosh" sound. It seems to boost better though. And im still blowing smoke out the tailpipe...it isnt coolant and it doesnt smell like burnt oil though.
Old Jul 27, 2010 | 03:08 PM
vjaneczko's Avatar
Refresh my memory - was it an intercooler hose that had a hole? And which hose did you replace? I'll guess the new hose is 'plugging a hole' that caused the sound difference.
What color is the smoke? And is it barely visible or is it like a curtain you can't see through?
Old Jul 27, 2010 | 03:42 PM
ibified's Avatar
The hose I replaced is the flexible one between the hard pipe off the turbo and the hard pipe that goes to the intercooler inlet at the bottom. The smoke isnt always there, and it varies. Sometimes i can barely see it, sometimes it's coming out pretty thick. It's been doing that since i got the car. I'm wondering if its the turbo or the cat going bad. I have an exhaust leak at the time, so its hard to determine...
Old Jul 27, 2010 | 04:01 PM
vjaneczko's Avatar
It can't be the cat, 'cause it doesn't remove smoke. PCV maybe?
Old Jul 27, 2010 | 08:22 PM
91shelby's Avatar
pcv system? check under your plastic head cover is there oil under there?
Old Jul 27, 2010 | 11:56 PM
ibified's Avatar
I just did the PCV system about 400 miles ago.
Old Jul 28, 2010 | 08:56 AM
vjaneczko's Avatar
Did the smoke appear after the PCV job, or was it always there? Did it get better or worse?
Old Jul 28, 2010 | 08:59 AM
ibified's Avatar
It's always been there, and I honestly dfont know if it got better or worse, because I did the PCV system within a couple weeks of getting the car.
swiftjustice44
Oct 25, 2012 06:32 AM
al_ngl
Aug 27, 2011 07:25 PM
96960Chris
Jun 25, 2011 04:49 PM
battlewagon240
Nov 10, 2009 11:48 PM
gabyman97596
Jul 1, 2007 11:00 PM
