Lower motor mount advice
Old Mar 6, 2012 | 02:48 PM
TonyS's Avatar
Default Lower motor mount advice
I'm replacing that lower motor mount behind the passenger-side wheel on my 1996 850 NA wagon with 168K miles. Not too soon, apparently, since the mount has collapsed to the point where it's not possible to get a socket in there to turn the 17 mm lower bolts. I measured the mount that's in there from top to bottom. It seems to be about 3 inches tall. The replacement is about 3.5 inches.
So my strategy is to remove the top bolts from the mount to the engine, then jack the engine a half or three-quarters of an inch so I can get a wrench in there. Seems obvious enough, but is there something I'm overlooking? Thanks.
Old Mar 6, 2012 | 05:06 PM
You got it man. You may have to jack a little higher than that. Make sure you use a wide flat surface to jack the motor up. I usually jack up the oil pan with a 2" x 6" x 1'. Just did it yesterday.
Old Mar 6, 2012 | 05:38 PM
boxpin's Avatar
The oil pans crack pretty easily so put the jack + 2x6x1 on the edges not the center of the pan
Old Mar 16, 2012 | 10:54 AM
TonyS's Avatar
At least I didn't replace a part that wasn't actually worn out.
Thanks for the advice.
Old Mar 16, 2012 | 01:50 PM
I'd say that one was blown. Yikes!!!
Old Mar 17, 2012 | 12:51 AM
When you talk about getting your moneys worth out of something ..... I think you are definitely there on that one !!
Old Mar 17, 2012 | 01:06 AM
slimflex2's Avatar
changing my lower motor mount made the engine much more responsive. noo more movement nor vibrations.l used to get some sort of vibrations on accelations but now stopped.am looking into changing my front mount and upper motor mount too.
OldVolvoGuy
May 7, 2015 01:31 PM
srussell39
May 3, 2012 07:02 AM
usedS70
May 28, 2008 08:41 PM
