MAF or IAC?
Old May 9, 2013 | 07:18 PM
farrens77's Avatar
Default MAF or IAC?
So I have this problem with my 96' 850 Turbo I'm hoping someone can help with. My car does fine driving and accelerating until it warms up and I get into stop and go traffic. It'll start with the rpms start to drop almost to the stalling stage(which sometimes does) almost like it's loading up? It'll start to stutter and puffing black smoke out of the exhaust. Tonight it got so bad that I couldn't accelerate hardly at all and tried stalling at every stop light(which really sucks in rush hour traffic). Usually It'll come out of it after I get it opened up on the open road a couple times. I've cleaned the IAC and MAF last weekend in hopes that it would fix the problem but evidently wasn't. Could one of these still be bad or do I need to start looking at something else?
Old May 9, 2013 | 11:02 PM
Do you have a check engine light on at all ??
Old May 10, 2013 | 07:03 AM
farrens77's Avatar
Yes I do. had it checked out and have 2 codes PO440(evaporative emission system) & PO133(O2 sensor slow response).
Old May 12, 2013 | 06:30 PM
farrens77's Avatar
OK. So I feel defeated with this problem. I bought a new MAF yesterday and I'm still having the problem? I just don't get it! I've done everything I know to do and I can't figure out the problem? Someone with more knowledge with these cars Please Help!!
Old May 12, 2013 | 07:02 PM
Have you followed the evap system hoses to see if one has come loose or is damaged and leaking ? The canister is located behind the bumper in the drivers front corner.
IF ,,, if you have both a vacuum leak and a bad O2 sensor it could be your problem with it wanting to die at idle.
You might want to repost your question with the same info in your first post but put the two codes in the title. Might get a better response. Remember to add that you've already tried a new MAF.
Not to sound crazy or beat you up but why not buy an O2 sensor ?? What led you to buying a new MAF ??
Attached Thumbnails MAF or IAC?-emissions-carbon-cannister-system.jpg   MAF or IAC?-emissions-carbon-cannister-system-turbo.jpg   MAF or IAC?-emissions-carbon-cannister-drvs-fender.jpg
Old May 12, 2013 | 07:28 PM
farrens77's Avatar
I bought the new MAF because I cleaned the old MAF with the cleaner one day it was acting up and it was fine immediately after reinstalling it so I figured it was bad. I also was reading other members problems similar to mine and everyone seemed to point to the MAF being bad.
tr_car_nut
Sep 9, 2009 09:50 AM
tobra
Sep 7, 2009 10:21 AM
Chebucto
Jun 7, 2009 01:29 PM
ricky
Mar 9, 2009 07:07 PM
Delirious
Feb 17, 2009 03:51 PM
