main headlights wont come on
Old Oct 23, 2011 | 09:49 AM
  #21
Replace the ignition and see if any problems remain. It is possible that you have unrelated problems but I would tackle the big problem first.
Old Jan 4, 2012 | 07:50 PM
  #22
Aerie's Avatar
Originally Posted by and240res
Wanted a few days to see if the trick of moving the key would make the headlights come on, since they would work normally some days. Moving the key worked every time the lights would go out, and also brought back the econ/sport/winter mode switch , shift lock unlocks now, and even the seat belt warning lights . High beams are still out.
It didn't have an effect on the blower fan for heat/AC. it is on most of the time, when you drive the car at any speed . It blows warm air into the car, No way to turn it off or regulate the speed/ temperature.
I will be ordering an ignition switch and checking the relays on top of radiator, as there's still clicking coming from somewhere around there.
Thanks so much for all the great advice!!!
Did you happen to solve any of the issues? I have the same problem with a 1993 850 GLT. Headlights work fine, but climate control unit blinks, and the fan only comes on when the headlights or parking lights are switched on otherwise the fan doesn't work at all. I can not control the speed or change it from defrost.
Old Mar 15, 2012 | 10:18 PM
  #23
youmeill's Avatar
Do your high beams come on?Have you checked the fuses?Do you have a test light?Would also check the fuses for any corrosion in them, weird about the fan?
Old Mar 16, 2012 | 11:18 PM
  #24
The fuse box is a good place to spray WD40. It helps keep corrosion down and makes it a bit easier to pull a fuse should you need to replace one. That or if you have the time to take "bulb grease" and pull each fuse and actually dip a bit on each blade of each fuse and stick them back in.
Old Aug 24, 2012 | 10:31 PM
  #25
Paramedic835PR's Avatar
I had the same problems of the main lights not working on my 1990 740 and the trick of wiggling the ignition switch worked like a charm. Thanks guys.
Old Aug 25, 2012 | 09:26 AM
  #26
Brick850's Avatar
Paramedic, if you need to jiggle the ignition switch to get anything to work, your switch is failing......look at replacing it sooner than later.
Old Aug 25, 2012 | 01:06 PM
  #27
What he said, if it's starting to go, get it fixed before it strands you with a no start and wiggling won't help
Coach Dad
Jul 27, 2011 06:26 AM
VDriver24093
Feb 21, 2011 04:35 PM
maximumjeremy
Oct 26, 2010 12:25 PM
dwaino@live.com
Aug 6, 2010 07:34 PM
lipsro1
Jul 31, 2010 01:39 AM
