Major problem #1, only making 5 psi
Did a temp hookup of a boost gauge cause I ad a feeling I wasnt boosting what I should. I'm not. Only getting 5psi consistent, spikes after shift to maybe 8-9 psi. What should I check (read below first)
Background that will help diagnose:
Head was just replaced with a rebuilt one. Labor done by Volvo dealer. Many small parts replaced same time, like gaskets & hoses. And most vac hoses at same time. I tightened all the hose clamps I could reach to & from the intercooler. Only vac lines that look old are the ones going to the wastegate & the wastegate actuator. Look dried. Going to replace, but want to do it all one shot. And I am not getting any check engine lights.
Aside from the vac lines that look dry (no holes & its a consistent 5 psi) what else should I check??
Thanks guys!
Thanks guys!
PinnacleWax
05-08-2015 01:05 PM
