Might be getting 850 T5.
Old Mar 13, 2006 | 01:38 AM
tm_94altima's Avatar
Default Might be getting 850 T5.
Well my dad is getting me a new car. We are currently looking at a 1997 Volvo 850 T5. I have a couple of questions.
1) Are there common problems to look out for?
2) Any factory defects or recalls to look out for?
3) Does it have LSD?
If I get the car, I will probably be a very active member here. Thank you very much.
Old Mar 13, 2006 | 09:42 PM
Default RE: Might be getting 850 T5.
Search the 850 section as well.
The most common problems are the Evaperators and ABS modules.
The rest os normal wear and tear stuff. Suspension,engine mounts,Axles, ETC
Old Mar 14, 2006 | 02:12 PM
Thanks, I tried searching but I am having trouble with too broad of a search (the word problem shows up in nearly every thread) or no results at all. But I got some good search results for "newb" that helped me out. I still haven't found the answer to my question of does it come with LSD.
Old Mar 14, 2006 | 06:03 PM
JimKW's Avatar
What is LSD? It wouldn't have anything to do with Jerry Garcia would it?
Old Mar 14, 2006 | 08:48 PM
robert213's Avatar
Browsing thru owners manual...
http://apps.volvocars.us/ownersdocs/.../97850_000.htm
I did NOT find any reference to Limited Slip Differential. Our cars are FWD. I don't know of any other FWD vehicles with LSD. I know that my 1993 Honda Accord EX does not.
You may be able to find LSD with Euro-spec 850 with 5-speed manual transmission -- not in the U.S.
Old Mar 14, 2006 | 09:53 PM
ORIGINAL: tm_94altima
Just look though the 850 Section from the main screen of the forum.
No on the LSD
Old Mar 14, 2006 | 10:56 PM
B1mmer's Avatar
ORIGINAL: robert213
I'll give Robert a little lesson on FWD cars that come with a standard (torsen type) LSD:
Acura Integra Type R
Mazdaspeed Protege
Civic Si ('06)
Sentra SE-R Spec V
Saturn Ion Redline
Chevy Cobalt SS
'91-94 Sentra SE-R and NX2000 came with a viscous LSD... not as good as a torsen, but better than an open diff.
Volvo has never offered an LSD in any 850/V70's. Traction control is considered by some to be an 'electronic LSD', but from someone who races cars, it's not even close - AB
Old Mar 15, 2006 | 11:25 AM
JimKW's Avatar
Limited Slip Differential. I can't understand why I could not figure out what LSD stood for. I believe GM used to call that Posi-Traction in the Chevelle. I had it in my 69 Malibu and with snow tires that car would go anywhere in the snow.
Old Mar 16, 2006 | 01:49 AM
Thanks for the responses. My 94 Altima has it. But it was only available with the SE or as an option.
Old Mar 17, 2006 | 03:45 PM
B1mmer's Avatar
TM... that's not correct. Your car came with an open differential from the factory. No Altima every has had an LSD standard or optional, even the 2005+ SE-R edition. Here's a link to some data on your ride:
Click Here
Look under limited slip differential in the Braking and Traction section. - AB
Old Mar 17, 2006 | 04:29 PM
ORIGINAL: B1mmer
Click Here
http://www.nissanforums.com/showthre...p+differential
Here is the thread where I learned about it, and using the tranny code given by KATech, I found out that mine has LSD. I also read about it in Motor Trend's 93 Import Car of the Year competion.
92Typhoon
Apr 9, 2008 10:07 PM
jdennis
Mar 27, 2006 10:56 AM
wufmama
Aug 11, 2005 09:53 AM
rhythmkitchen
Oct 7, 2003 02:43 AM
