moon roof slide carpet came off
Old 04-19-2005 | 02:40 AM
floryed's Avatar
Default moon roof slide carpet came off
The moon roof slide that is carpeted... you know the thing that slides back and forth, so as to hide the moon/sun roof. Well, the carpet came loose, and I ripped it off. It is not destroyed, only I took it off, and cleaned the plastic sliding cover. I was wondering if I could glue it back on, or what I can do to put it back on without too much trouble. It looks like I may have to take it out first, and to glue it, I don't know what I can use for that. Any suggestions would be greatly appreciated... as usual. Thanks again.
Old 04-19-2005 | 11:34 AM
Default RE: moon roof slide carpet came off
You will have to take it out to do it.
I have to try to remember how to get it out.I think you have to remove the glass then it might slide out.
They best way to try to get it to hold back on would be to use spray adhesive.
Old 04-19-2005 | 09:05 PM
knight rider's Avatar
I had this problem too. Mine had not come completely off and I just isolated the carpet by taping newspaper around it and laid a towel on the seats below and sprayed a thin layer of adhesive. Worked like a charm
Old 04-20-2005 | 01:20 AM
floryed's Avatar
Thanks for the info fellas. I'll try these tips for sure!!!
Old 05-01-2005 | 01:36 AM
floryed's Avatar
What would be the easiest way for me to take the glass of of the sun roof, so as not to break anything, so that I can take off the sun visor to glue the carpet back to it?
Old 05-01-2005 | 03:30 AM
Tilt the sunroof up.Then remove the plastic covers hiding the screws.Then remove the 4 screw and then the glass.
Old 05-01-2005 | 12:45 PM
floryed's Avatar
Do you mean the first picture that I took. It only shows the one side. Now this is of the sun roof tilted in the up position. Or is it some of the screws in the second picture, where the sun roof is completely open? Now, I believe you are talking about the first picture. When I take the 4 torque screws out, the glass, and it's connecting arms, should all come with it, correct?
[IMG]local://upfiles/1748/85DC30C1C3BC4AF8AF0983F3FA2D2A8A.jpg[/IMG]
[IMG]local://upfiles/1748/A2CC2B2420B54EA8AC4CF67F2F56391A.jpg[/IMG]
Old 05-01-2005 | 02:57 PM
Neither once you tilt it open look in the angle part <There is a plastic peice that goes from the glass to the body.You either slide it foward or backwards to unlatch it and remove it then there it 2 screw that go through the glass into the sliders.
Old 05-02-2005 | 12:05 AM
floryed's Avatar
Okay. I looked at the angles themselves, meaning when you tilt the window on each side the angle of the widow has a bracket that holds up each side of the window. The plastic piece snapped out of the bottom, and slid off to the back, and it was removed. The two torque screws on each side toward the front were removed, and window came right out. The plastic cover was heald in with four clips, and it came right out. The entire job took 10 minutes. Wish me luck on gluing the carpet back on. I hope it comes out okay. I will use the spray glue as advised. Thanks guys!!!
Old 05-02-2005 | 02:15 AM
Keep us posted and take pics to let us know how it went.
Old 05-03-2005 | 04:37 PM
floryed's Avatar
The first picture is of the sun roof cover all glued. The second shows what happens when you put too much glue on the plastic piece. WARNING!!! Do not put spray glue on the carpet itself. Make sure that after you spray the glue, you spread it all around until it gets tacky. Then put the carpet piece on, and quickly. Once it gets tacky, it dries fast, but if you put it on too fast, it will seep through the carpet, and leave nasty stains. Anyway, I found that out the first time. I took the original carpet off, and tossed it. I went to the fabric store, and got another piece of beige cloth, one that is exactly like the trim around the sun roof. I sprayed the glue, rubbed it until it was tacky, and then applied the cloth. Afterword, I cut the cloth to the right legth. I did tape off the spots that I did not want glue to be, and after the carpet dried on the plastic piece and the tape, I cut the carpet/cloth piece right at the edge of the tape, and peeled it off. It came out great. Anyway, the third picture shows the two screws that need to be taken off after you tilt the sun roof, and the others show the cover on the screws, and the sun roof cover closed. Good luck to anyone doing this... and remember to be careful with the glue, otherwise you will be doing what I did, or living with a crappy looking cover.
[IMG]local://upfiles/1748/2D6E00D9B6924CDCA98F978A2F0FAEB4.jpg[/IMG]
[IMG]local://upfiles/1748/ED6E278765C54E5BBA1E71F15BECE126.jpg[/IMG]
[IMG]local://upfiles/1748/9881387ACDDA49A898DEEC312FD7D91C.jpg[/IMG]
[IMG]local://upfiles/1748/F0B65236C52D4B33A9547A077B47D380.jpg[/IMG]
[IMG]local://upfiles/1748/7CE5ADD530EC4EE0BAB9EBB28EACE64F.jpg[/IMG]
Old 05-03-2005 | 10:55 PM
Thank you for the step-by-step instructions.
This will be usefull to people in the future.
bobmcgee6
07-21-2012 05:36 PM
MSGTUSMC
01-13-2012 05:37 AM
FishEyee
02-04-2011 08:01 AM
850forum
09-30-2008 06:43 PM
otis1827
03-01-2007 10:53 PM
